AC Drain cleaning
No more wet feet...![soapbox](https://rennlist.com/forums/graemlins/soapbox.gif)
I was getting some water drips on hard left turns and I expect the horizontal drain that T's into the vertical down pipe that comes out above the TT to be plugged with dirt.
I have an extra drain pan on hand and I shaped a piece of copper tubing in such a way that it's fully inserted and pushed up against the opposite corner than pull it forward where the flexible tubing is in the most forward position.
I'm going to use a $5 HF can to inject some Clorox and after a while connect an air water supply to the pipe and flush it out.
This can be done with the HVAC unit in place just make a piece of pipe as shown in the pictures so you can deliver the cleaning products in the right place.
