MAJOR DESIGN FLAW in the 928
Hey guys have you noticed this? EVERY time I get in the car the IGNITION is on the WRONG SIDE!!!!
I keep thinking that the more I drive it that it will fix itself. But its still on the wrong side after two weeks!
We KNOW that the ignition is correct on the 911, because that was designed from the requirements of LeMans. And the 911 is and was born to race.
So MY 928 has this problem and its not working.
ANYONE else have this issue?
Everytime the same thing. I get in, try to put the ket in the left side and the ignition is GONE!! Its slid over to the right side!!
Oh well I will give it another couple weeks and report back.
![burnout](https://rennlist.com/forums/graemlins/burnout.gif)
I wonder if anyone has ever tried to change that??? With the steering interlock it might be hard, but if you left that part off I wonder if it could be done???
It's on the correct side for me with RHD .... gearstick as well ... but the wipers and the indicator stalks are reversed compared to normal RHD. I go from my DD to a 928 and turn the wipers on when I want to indicate, and indicate when its raining and I want the wipers on.
Thank goodness there isn't a difference in pedal layout from LHD to RHD.
In 17 years of ownership the only "real" design flaw I've noted is the rear sway bar drop links.
Simply not up to the job. I've broken three of them.
James
James
