What's the real purpose of brake dust shields?
Is it as in it's name to keep away dust from the brakes? Since I live in The Netherlands with usually enough rain to keep the country free of dust (although it hasn't rained for weeks now; rare), they'll have little function here.
Or is it also to keep away water during driving through the rain?
Reason I'm asking is that the mounting points of mine are toast, due to years of salty roads in winter. I won't use the car in the winter anymore, so can I remove them or is it wise to buy new ones (I think they're quite expensive)?
Part of their purpose is to keep brake dust off the suspension parts. Brake dust is harmful to anything it gets on. When it is not cleaned off wheels for an extended period it can ruin the finish. Same would go for other parts.
English PET calls it "Protective Plate" I always heard it called splash shield. Not much to do with brake dust. If you drive through water that is higher or hydroplanes past the shield, you should test brakes lightly to heat them a bit and/or get the water to go away. Otherwise you may have little or no braking.
If water were an issue why would the SCCA allow water cooling of brake discs with a water spray ???? That would seem odd ! Drum brakes tend to trap water but disc brakes do not have such an problem. My guess is to keep stones from getting wedged between a caliper and the disc.....
I agree that they are to keep debris out.
I hit a frog at about 130 and it bent the shield causing it to rub on the rotor and squeal like crazy.
Really freaked me out till is realized what it was.
Also had a frog get in the electric fan and stop it from turning.
These weren’t very big frogs either.
Water cooling is not...really liquid, and its not ON the brakes.
Its a high pressure mist INTO the brake rotors via the hub from behind.
It evaporates instantly, which increases the massflow of air THRU the channels (which is proportional to how well air cools things it passes over), and as the mist evaporates, greatly cools the air charge as well.
Its not water ON the brakes.
I've been curious on the effectivity of the brake shield with the installation of oversized wheels, or over sized rotors. Seem that in order for the shield to work efficiently it needs to be larger than the rotor and in close proximity to the inner edge of the rim. When people install larger rotors and bigger wheels do they also install larger shields?
Rest in Peace
Basic Site Sponsor
Basic Site Sponsor
Snow shields.
greg brown
714 879 9072
GregBBRD@aol.com
Semi-retired, as of Feb 1, 2023.
The days of free technical advice are over.
Free consultations will no longer be available.
Will still be in the shop, isolated and exclusively working on project cars, developmental work and products, engines and transmissions.
Have fun with your 928's people!
greg brown
714 879 9072
GregBBRD@aol.com
