Need help of torque tube bearing replace
I am replace my 85 ROW 5 speed torque tube bearing, there is 3 bearing and one damper, I know where to place the first and last bearing, but where should I put the mid bearing? and where is the damper located?
Need help and thanks!~![Confused](https://rennlist.com/forums/images/smilies/confused.gif)
![bowdown](https://rennlist.com/forums/graemlins/bowdown.gif)
Middle bearing goes in the middle.
Vibe dampener goes in between the middle bearing unit and the last bearing unit.
Make sure the vibe dampener is in good shape or it will separate later in the torque tube and then rattle around and shift the bearings from their places.
Good luck,
Good luck,
Rest in Peace
Do yourself a huge favor, get the superbearings and put that factory dampner on a shelf for disposal.
They will move around after they get old, just like Constintine says.
Thank Constantine, Vilhuer and blown 87
As blown 87 you said the factory dampner, do I have to put it in? Or I just take it out?
