928 Forum 1978-1995
Sponsored by: 928 Specialists
CE Panel 94 GTS
Old May 10, 2011 | 08:50 PM
77tony's Avatar
77tony
Veteran: Army
Default CE Panel 94 GTS
This red power wire located in the top left slot of the "S" component is a little baked and needs to be replaced, but would like to know where it goes so it can be fixed? Did trace it down the pass side up unitl the middle of the seat. Thanks in advance. Tony
File Type: jpg
File Type: jpg
Old May 10, 2011 | 09:38 PM
Jadz928's Avatar
Jadz928
I'm not an electrical guy, but consider what caused it the melt in the first place, or risk having it happen again.
Old May 10, 2011 | 09:49 PM
fraggle's Avatar
fraggle
You should be able to check the wsm wiring diagram to see what it feeds and decide if you should be really really worried or not. I wouldn't drive the car until things are sorted, that's a heavy fire risk.
Old May 10, 2011 | 09:57 PM
jcorenman's Avatar
jcorenman
Tony, that is terminal S15, Sheet-11 of the 94 GTS wiring diagram, right-hand side (coordinates O-96).
It's a 0.5mm red wire that feeds power to the inside light(s) in the rear tailgate, and the inside light in the roof.
The power source is bus 30 (12v always live) via fuse 25, which also feeds power to a bunch of other lights through different circuits. That particular wire only feeds the tailgate and roof lights, that junction is connector "T10" in the B-pillar.
I suspect a short in there somewhere. Do those lights work? Any history there?
Cheers, Jim
Old May 10, 2011 | 10:51 PM
borland's Avatar
borland
Might be easier to replace the wiring harnesses downstream of the T10 connector, then repair that burnt wire up to T10 connector and any damaged wires behind the CE panel. A late model parts car should have the same inside light harnesses as your GTS.
Old May 10, 2011 | 10:57 PM
fraggle's Avatar
fraggle
Wasn't there a recent thread about that harness shorting in the roof somewhere? I'd cut the connection until willing to dig further.
Old May 10, 2011 | 11:00 PM
WallyP's Avatar
WallyP
Rennlist Site Sponsor
It is VERY common for the power wire for the light over the rear view mirror to short to the body.
Old May 10, 2011 | 11:21 PM
77tony's Avatar
77tony
Veteran: Army
I'll get to this before I have breakfast ! Thanks to all for your help. T
Old May 10, 2011 | 11:48 PM
pcar928fan's Avatar
pcar928fan
I bet something got a little crimped when the new headliner went in. That would not be uncommon at all I wouldn't think! Thankfully you can pull that wire and never worry about it again or fix it...either one. Of all the wires to have messed up that is a really really minor one but certainly could still start a fire.
Good luck and take pics when you trace the problem down.
Old May 10, 2011 | 11:59 PM
77tony's Avatar
77tony
Veteran: Army
Where could I find this wiring diagram for the 94? James, where & what time is the Austin Gathering this Sat? Thanks, T
Old May 11, 2011 | 12:01 AM
pcar928fan's Avatar
pcar928fan
Tony,
We are having lunch at Bone Daddy's on Hwy 183 at the Duval exit (the Bone Daddy's is on the East side of 183 on the north bound access road). I will be there by 11:15, most folks start getting there between 11:30 and 11:45.
I can't wait to see "Just Beachy"!!!
Old May 11, 2011 | 12:03 AM
77tony's Avatar
77tony
Veteran: Army
Thank you James. Looking forward to meeting up with the Austin crew. T
Old May 11, 2011 | 12:06 AM
pcar928fan's Avatar
pcar928fan
Tony, I like your car the more I see it! If it is half as beautiful in person as it is in photographs you better keep your keys connected to you at ALL TIMES!
Old May 11, 2011 | 01:09 AM
jcorenman's Avatar
jcorenman
This guy Roger, down your way, sells the Jim Morehouse CD's with all sorts of good stuff including the WSM and wiring diagrams.
Old May 11, 2011 | 06:30 AM
Vilhuer's Avatar
Vilhuer
Morehouse CD is well worth the $$. In case diagram is needed quickly:
http://www.cannell.co.uk/Manuals.htm
