Any commonly available replacement for the ex-foam under the injector covers?
Unfortunately, my neighborhood hardware store is Lowes, but considering the 220F test was not a complete meltdown, I guess I'll give it a try and see how it holds up. Thanks for sharing your experience.
For those that didn't go back and read my original post, though, please be aware that the normal pipe insulation foam from Lowes will melt, at least somewhat, under as low temps as 220F.
Chronic Tool Dropper
When Dr. Bob did his intake R&R, he had a couple of rolls of a thin adhesive foam that is almost exactly the width of the rails. It is very similar to the foam strips used by Porsche to cushion the fuel tank strap cradle. Being Dr. Bob, he also had some gasket cutting punches, so he covered the rails head to toe with the stuff, making cutouts for the injector rails:
The insulation I used is 1" wide foam gasket material with an adhesive back. For the sides I cut it down to 3/4" wide. Top and bottom are full width. I added cable ties to make sure the insulation stays put. The ties are hidden by the covers pretty much.
