928 Forum 1978-1995
Sponsored by: 928 Specialists
New oil control solution for Race/ORR/SC/Stroker/GTS/GT/CS/SE/S4/S3 928 Engines
Old 08-31-2011 | 08:02 PM
  #376
Kevin Johnson's Avatar
Kevin Johnson
Originally Posted by James Bailey
The 1994 Letter about the head restrictors was sent to Kim Crumb. His GT experienced TWO engine failures , after that date as I recall.
I guess that would be a good indication that oil packing into the heads from the circuit was not the source of the 2/6 rod bearing failures.
Old 08-31-2011 | 08:12 PM
  #377
GregBBRD's Avatar
GregBBRD
Former Vendor
Originally Posted by rad_951
Greg,
Is the pump you are using able to withstand sucking in lots of air when the engine is operating under street driving conditions?
FWIW I have seen lots of engines fill or overfill their catch cans connected to the valve cover vents at the track. On the 18th I saw a 951 overfill a large catch can and oil two corners. I don't think the car was out there more than 20-30 minutes. My Vett fills a small catch can in 20 minutes with a new engine! It seems to me ALL engines fill the heads under track conditions.
Tony
In theory, yes the pump will work without much oil going through it. Time will tell.
I have heard, recently, that the newer Chevy engines do "pack" oil into the heads, also. I have no idea. I know a lot about very little.
Old 08-31-2011 | 08:17 PM
  #378
Kevin Johnson
So, I guess you are saying that now you do not want a free system to test. No problem.
Once again, from five years ago, to refresh your memory:
The stock Porsche 928 V8 wet-sumped engine, both 16V and 32V versions, has two very well known problems at rpms above ~6300 rpm: 1) oil aeration which is definitely fatal to the engine; 2) oil ejection. Many, many attempts have been made by the factory and aftermarket to correct these problems in the 30 plus year history of this engine.
With regards to the fatal problem of oil aeration, the Ishihara-Johnson 928 windage control system allowed the Dutch Stallion team to run their wet-sumped 928 S4 engine at typical rpms of 6800 for the first half of the 43 hour 2006 season (not including practice) and 7200 for the second half with stable oil pressure. This was accompanied by a 10 degree Celsius drop in coolant temperature from the previous years engine which had less power. This years engine is NA and develops 420 rwhp.
To our knowledge safely running this sustained rpm level in the wetsump engine is unprecedented in the history of this engine*.
Prior to the installation of the windage control system when they attempted to run their engine at 6800 rpm it failed in two days.
Upon teardown of the engine at the close of the season no discernable damage had occurred in the engine.
Testing trumps theory, right?
And then:
To be very clear, the windage control system does not and cannot correct the second problem of oil ejection. In some situations it may even make it worse.
Louie Ott, in a Rennlist post suggests:
The oil filler breather I made can be seen on my web site on this page.
http://www.performance928.com/cgi-b...ass_parent=1128
Scroll down to the bottom and there are a couple of pics. I have some basic drawings (no dimensions) which I could email if you want. The inside of the aluminum cap has the threaded part from the old cap. Turn down the outside of the old cap. Turn out inside of the new cap to fit outside of old cap. Epoxy old cap inside the new cap. A hole has to be bored in the old cap to fit over the swivel projection in the center of the new cap. The size of the copper pipe "street L" that goes into the center of the cap is 3/4" and is about the smallest size I'd consider using. If there is a way to use 1" size, use that. It might fit. This was just an experimental thing and it worked out ok. You need to vent a large volume of blowby, but don't want high velocity which would carry oil with it. That's why the largest diameter you can use is best. I don't know what others have made. One key thing is to have the inlet on the underside of the cap project down into the filler so any oil that is on the surface has a hard time turning the corner and going up and out the breather.
Rob van Kol has used Louie Ott's suggestion and added a baffle trap as well. The oil ejection rate for the Dutch Stallion Team car is now at .25 liters per 50 minutes racing. These suggestions really work.
* To our knowledge safely running this sustained rpm level in the wetsump engine is unprecedented in the history of this engine. ...
In the mid 1990s, Porsche helped Max Moritz Racing compete as a semi-works team with the 928 GTR. Near the end of the season the hand selected engine provided by Porsche suffered the dreaded bearing failure.
See also the Kibort Effect for long term survival of the stock engines at lower sustained racing rpms.
During the development of the 928 engine there were strength problems with the original bedplate design. This bedplate design did have better windage control characteristics. These elements were largely sacrificed in favor of strength. It can be seen that Porsche was dealing with crankcase flow issues that later entangled Ford in the Modular V8 for many years. The oil pump was progressively driven faster and faster to compensate for aeration issues in this early development time and even a deaerater design element was incorporated into the large sickel pump. Unfortunately, the original oil sump design was also subsequently altered in the production engine after previously undergoing all this development, including a 3000 hour durability dyno test at full load and multiple 600 hour runs. See the chronicle entitled "Project 928."
Originally Posted by GregBBRD
You are mistaken...I'm not even close to being pissed off.
I'm just not going to argue about something that I have proved to my own satisfaction.
Thus the "testing trumps theory" comment.
You can sit in front of your computer, all you want, debating what happened on the dyno, but the reality is....oil did "pack" into the heads....in large volumes....leaving very little oil left over, in the pan, for the pick-up. I don't see that your "windage" system is going to keep this from happening....it may "help" or "slow" the process, but the heads are going to fill with oil and the pick-up is going to get "uncovered".
I'd agree that there are a few engines that have Accusumps on them that have survived...but this simply "masks" the issue. I'd also agree that Kibort has developed a driving style that makes the engines live....combined with used tires that have very little "stick" left in them.
However, I can't train everyone that uses one of my engines to drive like KIbort....and I don't like "masking" problems. I want to "fix" the problem...so I don't ever have to think about it, when one of my engines leaves my shop.
Everyone else is free to do whatever they want....
BTW....did I notice that Carlhole equipped his engine with both one of your windage trays and a system to remove the oil from the heads? Why would he do this, if your system "cured" the problem?
Old 08-31-2011 | 08:20 PM
  #379
GregBBRD's Avatar
GregBBRD
Former Vendor
I believe those valves were designed to limit pressure, not volume....
If they wanted to limit the volume, it would have been way simpler to just put in a restictor...not those elaborate valves.
I'd guess that at operating temperatures, the volume delivered to the heads will be very similar to the original pieces.
This, combined with the obvious tensioner problems on the 944S engines, is why I didn't bother with these valves.
Old 08-31-2011 | 08:29 PM
  #380
GregBBRD's Avatar
GregBBRD
Former Vendor
Not at all, I'd love to test your product, in an actual dyno test, for you.
Obviously, you have not done this, for a 928 engine.
I just don't want to debate the reality of my testing. That would be silly.
Old 08-31-2011 | 08:51 PM
  #381
Kevin Johnson
Originally Posted by john gill
Hello All
I have stated this before , my project car which can be seen of the url at the base of this message , has the head restrictors and the I and J windage system in place . In my Dyno ( MY DYNO ) at 6000 rpm the heads fill with oil instantly , filling the catch can and overflowing , to help me finish the tune in the dyno I put the overflow line ( which incidently was considering to vacuum source this ) into another reservoir on the floor .
A frightening prospect for this to happen on the track , any wonder they grenade , GBs system will allow the heads to be kept clear and oil in the sump although to seriously track this engine, as I will be with the next project , I will be dry sumping it . As I will be running it over 7000 rpm to which I believe they can easily perform to.
Interesting that the GT cams were designed to run up 6800 rpm , particularly when they must have known that they were suspect up to this speed .
I see references online that list the peak horsepower of an S4 at 6000 rpms. Typical durability testing for OEMs is hundreds of hours on the dyno sweeping back and forth between peak hp and torque. The designs of the sump elements indicates that a large amount of aeration takes place. Greg is not measuring the bulk density of the "oil packing into the heads" nor the bulk density of the oil in the sump. That is very difficult to do accurately. Mercedes used radioactive isotopes in the 1970s. Porsche styled their sump design after Mercedes but the slope of the rear of the pan is much less in the Porsche engine.
... I have been sitting on the sidelines watching this thread , I am never ceased to be amazed at some people who want to argue black is white and visa versa , oh well if you want to band aid the system you will install put a windage system in , if you study the oil system in detail in the 928 you will see that heads have no pressure feed system back to the sump reservoir , the space in the heads allows for much more then the volume of the sump to accumulate oil . As it is only fed by gravity and is being fed by to 10 bar , simple application of mathematics accompanied by observation in my case ,the dyno cell , it all becomes a mute point .
What was the percentage of aeration in your oil? A windage system affects the equilibrium levels.
After watching Rennlist for a while now , I would forward my opinion that to discount GBs experience and assertions would be the height of ignorance . I for one am glad that he regularly posts and forwards his opinions, remember that this is free , his experience here has been accumulated from years of ecperience and trial and error.
His development and observations of this problem has cost hundreds if not thousands of hours , and offers a solution to a problem that the factory walked away from .
I am sorry but he needs to do more research on existing research. Other people and companies have spent far greater amounts of time and money to scientifically study these problems.
Old 08-31-2011 | 09:21 PM
  #382
Kevin Johnson
The missing data here is how much oil flows through the system after the pressure relief valve in the pump kicks in. With most pumps the volume stays fairly constant -- gradual rise with increasing rpm.
Old 08-31-2011 | 09:23 PM
  #383
Kevin Johnson
I will need the stroke and outer swept diameter of the counterweights.
Old 09-01-2011 | 12:10 AM
  #384
IcemanG17's Avatar
IcemanG17
great discourse...... honestly we are lucky that people like Doc, Kevin and John continue to test and improve the inherently flawed 928 oiling system....
I am proud to continue testing the on track limits of a slightly modified 928 oiling system....so far it has proven reliable...but I am sure changing only a few variables would drastically change my results... I am sure the low RPM powerband of the USA 4.7L helps keep the engine alive...while my engine spends significant time on track, most of it is fairly low in the RPM range due to the tall gears of the automatic and powerband that falls off a cliff after 5500rpm...
If I were building another 928 race engine, one that made power well past 6000rpm...which is quite easy to make happen....I will drysump it.... with stages that scavenge the heads... there still is lots of uncharted territory in 928 engine building....a big displacement engine that CAN spin to big RPM....do the math on that....crazy power...Mike Simard gave us a small taste of what can be done....with a streetable cam and low compression.... Imagine a true 454 at 13+CR with a lumpy cam running race gas.....700+ whp with ease.....not to mention BOOST
Old 09-01-2011 | 01:52 AM
  #385
Jim Devine's Avatar
Jim Devine
There isn't any major form of racing that doesn't use dry sumps that I'm aware of. After the oil has done its job- pumping up the lifters, lubing the cams & cooling the springs, it just makes sense to get it out of there. Greg has done a great job & it's a very neat installation. It's amazing how he can fix things the factory could not or chose not to.
Old 09-01-2011 | 06:19 AM
  #386
Kevin Johnson
Fairly recently there was an opportunity to watch this sort of engineering/accounting/? debate go on in an OEM. First, though, Mercedes does present dry sump aeration data in that 1975 SAE paper alongside the wetsump data. Perhaps to say to Porsche that if you really exceed the parameters of these tests then take this path. I do not think Porsche had the money to redo everything; many people here have the experience of trying to figure out where to locate dry sump components for a 928 street car. Even now, Porsche chooses to try to integrate the dry sump style system within the area of the engine itself.
The Modular V8 in the Ford GT was dry-sumped and used a full windage tray system. More importantly, the block was re-engineered with respect to the head drains and breathing/pumping of windage and blowby gases. So they already had this solution in hand. When the Coyote 5.0 was developed they passed over using the now-already-available dry sump and instead continued playing with the existing passages (and adding new ones) -- again with a full windage tray. The Coyote motor is more advanced technologically and you could certainly choose to add a dry sump to it. Something to think about.
Old 01-16-2012 | 05:35 PM
  #387
john gill's Avatar
john gill
Hello ALl
THis has popped up on the 944 board , will these Clevite high performance Nascar rod bearings CB-1628HX fit the 928 ?
I was not aware that the 944 968 shared a similar size bearing to the 928 ?
Old 01-16-2012 | 06:33 PM
  #388
GregBBRD's Avatar
GregBBRD
Former Vendor
Hello ALl
Yes, 944 and 928 share the same rod bearings with the 928 engine.
That Clevite bearing is significantly narrower than the stock rod bearings. Not exactly sure what that is going to do...I've been thinking about that, since I saw that post on the 944 board.
A "Chevy" rod uses a much narrower rod bearing, but the rod is also not as wide. That narrower bearing is limited on how far it can rock, by the thrust surfaces touching the crank, or the other rod, in this application.
Seems like the narrow bearing, inside a wide rod could allow more "rocking" motion and thus accelerated wear on the edges of the bearing. I'm thinking of it as a "leverage" type of issue.
Keep in mind that a 944 piston is perfectly centered over the connecting rod and the rod beam is perfectly centered over the crank throw....this is easy to do, on a 4 cylinder engine.
In the 928 application, the rod has a "built-in offset" to accomidate the fact that the rod journal on the crank isn't centered under either of the two cylinders it serves. This is obviously going to "make" the rod try to "rock" on the rod bearing, every time the piston is pushed down.
However, I'm not sure if this is a significant issue. Might not be a problem, at all.
I thought that I'd run this past my friends at Carrillo and see what they think, next time I talk with them.
Old 01-16-2012 | 06:39 PM
  #389
john gill's Avatar
john gill
Thanks Greg
I wonder how much clearance between the bearings in the journal , in a stock 928 crank ?
I am about to dissasemble and check this in a stock block , nice to have options though ?
Old 01-16-2012 | 07:45 PM
  #390
GregBBRD's Avatar
GregBBRD
Former Vendor
Thanks Greg
.002"-.003".
I ordered one of those Clevite rod bearings to be able to look at them closer and see how they actually fit.
You know that I'm remaking 5.0 and 5.4 cranks with "smaller", narrower rod journals, less weight, and properly drilled for use in high rpm stock stroke engines? Should have the "first" cranks here, in about 3 weeks....but I've heard 3 weeks for the past 3 weeks. I have the rods already here, to fit these cranks.
This will be very trick stuff, for anyone that is using one of these engines in other than street applications, wants a "mini" stroker, or has a stock GTS with the "weak rods" and a 62 pound crank.
Quick Reply: New oil control solution for Race/ORR/SC/Stroker/GTS/GT/CS/SE/S4/S3 928 Engines
