ticking noise when hot
can anyone quickly tell me if i should worry. the ticking noise happens only when the engine ran for about an hour and increase with rpm?
lifters? injectors? Temp is fine, oil pressure is also fine at 5 cold and 2 when hot.
Barry
Barry
So the ticking arises after the oil is good and hot, thus pressure is reduced?
Sounds like a lifter is ticking because of the lack of oil pressure needed to pump it up because it's plugged up inside.
What brand and weight of oil do you run, and how often do you change it?
Team Owner
change oil to a heavier weight atleast 10W 40 ,
15W 50 preferred,
skip the ATF treatment for now
15W 50 preferred,
