Need photo of INSIDE rear bumper cover
I will take a Lowe's trip today looking for an idea. Thanks. I will follow up with what I do.
Thanks.
Well so far it looks much better. I purchased a 3'-0 long x 3/4" x 3/4" 1/8" aluminum angle. Had to cut about 3" off to fit from light to light. I used my DA and ruffed up the angle with 80 grit paper and I drilled several 1/8" holes in the leg that was being bonded to the bumper. I used JB Weld and set weights on it for 4 hours. The bumper shape is much better so far. I will get it mounted Saturday and see how it looks then.
Looks like a great solution. I am assuming the JB Weld will hold a long time.
Are the holes in the channel so that the JB Weld has a place to ooze through and lock the channel on? IE, you didn't use any mechnical fasteners, right?
Joe
Joe
Holes were just there to help the JB Weld have somewhere to ooze and form a head on. I'm not sure it helps but it sounded good to me at the time.
