Anyone running 18" Turbo Look Solid Spoke Twists?
Just picked up a set cheap and thought to see if they would fit or not. Otherwise I'll sell them off.
Front: 8 x 18 (offset 50mm)
Rear: 11 x 18 (offset 45mm)
Administrator - "Tyson"
Not yet, but I have 6 sets of 10x18 et65 stacked up in my garage.
No clue why I bought so many.
Front is iffy depending on rubber.
Rear usually works if you are okay with rolling your fenders and if you have a spacer that you remove. If you DON'T have a spacer and DON'T wish to finesse your fenders, the 11 and 45mm offset may be an issue.
Just put the rears on without a spacer (no tires). I will jack them into the wheel well and see it they fit without any lip roll. Looks close as is. 275 is the smallest tire I should put put on the 11" wheel, correct?
