a few 928 tech questions
i have an 81 manual euro model. 1.should 1 st gear have a synchromesh fitted ? 2.what co reading is correct for this model i have a machine i used to use years ago i was going to hook it up and fine tune the fuel air mixture? 3.whats the going rate for a used passenger side mirror in the states,im going on vacation in august and will try to source one while i,m there ?
Yes first was syncromesh. If you have grinding when you try to go from neutral to first it is possible the clutch is not disengaging completely. Usually second geari s the one that has worn out syncros from downshifting at speed or drag racing forced shifts up to second. One seldom needs to drop into first unless you have come to a full stop.
I may be wrong on this and I'm sure someone will correct me if I am, but if you are looking for the entire mirror assembly you may want to be careful, as I believe the angle the mirror sets at is different between right and left hand drive cars. If you put a US mirror on a right hand drive car you may not be able to get it adjusted correctly.
Your door lacks the internal bracket to which the factory mirror mounts.....take off your current mirror to see how it is attached, it is not simply screwed to the sheet metal.
