928 Forum 1978-1995
Sponsored by: 928 Specialists
17's vs 18's Only one set can stay. Winner decided see post 46
Old 04-10-2011, 08:39 PM
  #46
jpNcos
jpNcos's Avatar
Default Winner decided.
Sorry for crappy cell phone pics I forgot my camera.
Sumitoro HTR Z III 225/40/18 fronts 285/35/18 rears
Old 04-10-2011, 09:04 PM
  #47
Jon B.
Jon B.'s Avatar
Nice!!!!!! What did you do for fitment in the rear? Mine required a small spacer that would rather not run honestly.
Seems like 225/285 is the perfect combo for these wheels.
Old 04-10-2011, 09:15 PM
  #48
jpNcos
jpNcos's Avatar
My rear studs are the short style with no spacers. I could maybe run a small 5-7mm to push it out a little further toward the fender but probably won't.
Old 04-11-2011, 06:19 AM
  #49
tilac999
tilac999's Avatar
Originally Posted by jpNcos
Went with 35's on the rear due to nasty Colorado roads.
Just curious, why not go with 225/45-18 to match the rears?
Old 04-11-2011, 11:34 AM
  #50
jpNcos
jpNcos's Avatar
Mostly due to concerns with the et 50 working out. I went with what worked for others this go around. These are cheap tires that if they make it through the summer that is a bonus. They seem nice but I usually run PS2's. I didn't want to tear up the PS2's until I could confirm for myself that the wheel and tire combination would survive.
Old 04-11-2011, 12:57 PM
  #51
martyp
martyp's Avatar
Time to change your avatar!
Old 04-11-2011, 06:02 PM
  #52
pcar928fan
pcar928fan's Avatar
I didn't do that on EURO85 either...it also had the short studs and no spacers...I like them that way actually. Nice wide tire, but tucked in a bit... When they are REALLY NARROW 225's and tucked WAY IN, well, that is not pretty, but a 285 tucked in a bit...NOT BAD!
Brad, an 18" wheel with a 225/45 tire is going to have a pretty dang tall side wall. As was noted on S cars that ET50 offset is just barely getting by anyway, so you really want to keep that 225 tire as far away from the fender as you can...
Quick Reply: 17's vs 18's Only one set can stay. Winner decided see post 46
