1979 928 gearbox conversion
I own a 1979 automatic transmission left hand drive model, I have stripped the interior to lighten the car and fitting a roll bar as I plan to race her around our local track, where would I obtain pricing and detailed information for a new or used 5 speed gear box assembly, I am located in south africa, cape town, I am in love with the car and want to get her driving shortly.
If the rules allow it run it as an automatic because the parts needed for a conversion are many and very expensive. Finding a good used early gearbox that will allow downshifts into second is very unlikely, later borg warner syncro boxes are rare and much sought after. You need the bell housing , short shaft, torque tube,flywheel , clutch assembly ,slave cylinder, master cylinder, shifter, linkage, couplers, pedal assembly, blue hose, metal clutch lines, rear suspension cross member (depending on the box) on and on and on.......
