928 Forum 1978-1995
Sponsored by: 928 Specialists
knock senor condition
Old Mar 19, 2011 | 11:34 PM
the flyin' scotsman's Avatar
the flyin' scotsman
Default knock senor condition
Knock and Hall sensors were replaced in 09 as part of an overall intake refresh. Since I have it all apart again (different thread) I notice that an antifreeze leak has gelled onto the knock senors.
Question is would the antifreeze deteriorated the sensors...
Old Mar 20, 2011 | 12:13 AM
Lizard928's Avatar
Lizard928
No.
Old Mar 20, 2011 | 08:40 AM
oups59's Avatar
oups59
I say no. Those sensors are well protected.
Old Mar 20, 2011 | 10:27 AM
worf928's Avatar
worf928
+1. It takes a lot of heat cycles for gook to deteriorate the knock sensors. And, unlike some new parts from Porsche, the covering on the new knock sensors appears to be a different (perhaps better?) material that the originals.
Old Mar 20, 2011 | 10:33 AM
the flyin' scotsman
thx guys......just a little paranoid of component quality given recent events.
I'm sad to report though the new oil filler is leaking
Old Mar 20, 2011 | 10:59 AM
worf928's Avatar
worf928
From the base or the neck? If the latter, then, you need to separate the two pieces of the filler and reseal them with permatex black. (I learned this the hard way.)
Old Mar 20, 2011 | 11:32 AM
the flyin' scotsman
its leaking from the base where its bolted to the block.
Old Mar 20, 2011 | 12:09 PM
worf928's Avatar
worf928
Did you use a torque wrench when you bolted it down? Too much torque and it will warp.
Old Mar 20, 2011 | 12:15 PM
the flyin' scotsman
yes.........it was replaced with the intake refresh. I was very particular of torquing the knock sensors, all intake nuts/bolts and the oil filler. I wanted the project to last a very long time but it was not to be.
Old Mar 20, 2011 | 01:12 PM
worf928's Avatar
worf928
Oyi. Well... let us know what you find.
Old Mar 20, 2011 | 01:27 PM
the flyin' scotsman
As with the ISV hose I've requested my vendor to investigate with Porsche for nothing else to pull stock of possible bad components.
Compensation for parts and labour is perhaps out of the question.
Old Mar 20, 2011 | 02:56 PM
Mrmerlin's Avatar
Mrmerlin
Team Owner
Malcolm I would strongly suggest that when you refit the oil filler to add the 928INTL oil block off
Use a generous amount of Hondabond on the plate to block ,
and the plate the the bottom of the oil fill spout,
and goob some in on the O ring as well,
and then put it on .
You may have to do some test fitting of the Plate to get a perfect fit,
if you follow these instructions your oil fill should never leak again
Old Mar 20, 2011 | 08:50 PM
worf928's Avatar
worf928
... I've requested my vendor to investigate with Porsche for nothing else to pull stock of possible bad components.
Right. But, what's the failure mode? Is it because the plastic is warped at the base?
Old Mar 20, 2011 | 10:23 PM
the flyin' scotsman
Thank you Stan.
The 928 love hate pendulum is over on he H side at the moment and my recent experience with the California supplier wasnt great.
I'll chat w/our man in Tx on his return.
