CIS - now to learn this system
For my new to me 79 auto.
I've been reading posts for a couple days now with "CIS" in the title from several searches. I know I need to get a set of gauges... and to check ALL of my vacuum lines....
My car runs beautufully... possibly smooth enough to balance a nickel on the spyder body (ok, maybe not THAT smooth)... but nice and smooth.
My problem is that upon cold startup, it fast idles upwards of 1600-1800 RPM for about 90 seconds... then slowly retreats to a low idle of appx 1000... and no lower.
Vacuum leak? Would that have a proportionately higher RPM value for cold and warm conditions? I'm just getting started, but your insights are welcome.
Thanks!
Thanks!
Team Owner
the higher idle when cold is normal but it may be a slight bit too high.
I would investigate the vacuum lines and any other lines that carry air first.
Roger that, fast cold idle... I'm with you, it is too high, both cold and warm. I haven't even yet pulled the air cleaner box to fully look around. It may be an easy fix if there's a blatent cracked/broken line. We'll see when I can get it into the garage...
