928 Forum 1978-1995
Sponsored by: 928 Specialists
Did the 14 pin connector..ah geesh..
Old 02-27-2011, 11:11 PM
Speedtoys
Speedtoys's Avatar
Received 1,034 Likes on 623 Posts
Default Did the 14 pin connector..ah geesh..
Horray!
I have a working oil press gauge..
Oh wow..I have no temp gauge..
And as the engine warms up, the oil pressure goes from 5 down to 2...
*heh*
I guess I got somethin backwards.
SO..which two?
Old 02-27-2011, 11:13 PM
Jadz928
Jadz928's Avatar
did you take pics before disassembly?? Rut Ro!
Old 02-27-2011, 11:14 PM
fraggle
fraggle's Avatar
Oil pressure should drop as it warms up, that sounds normal, at least at idle. Does it move with RPM?
Old 02-27-2011, 11:15 PM
WallyP
Rennlist Site Sponsor
WallyP's Avatar
Check color codes on each side.
Speedtoys
Speedtoys's Avatar
Ya..never moves with RPM...I got somethin backwards.
Old 02-27-2011, 11:16 PM
Speedtoys
Speedtoys's Avatar
Wrote down what I saw...im 99% sure its messed up on the bottom, I had a few look the same down there. The top, was easier color matching wise.
Old 02-27-2011, 11:19 PM
Jadz928
Jadz928's Avatar
This is from an '86
Old 02-27-2011, 11:21 PM
Speedtoys
Speedtoys's Avatar
Wow..your colours came out a lot clearer than mine did...
Old 02-27-2011, 11:33 PM
Speedtoys
Speedtoys's Avatar
OH!
This does diagnose one more thing...
I wondered if the OP gague was stuck, or the sender was bad..well, I know the gauge isnt stuck.
Old 02-28-2011, 12:54 AM
The_Remora
The_Remora's Avatar
Related question: does the coolant temp gauge sensor wire go through this connector too? Mine recently stopped working after I did several projects and at some point I had this 14 pin connector apart during this and might have got some wires backwards. Sounds likely that Speedtoys did as well.
Old 02-28-2011, 01:51 AM
Erik N
Been selling Twinkies on Ebay,
have some extra cash right now.
Erik N's Avatar
I had that issue with my old engine, except the pressure guage would gradually drop to about 1 or less as the car warmed, and stay there.
The OP sender and housing was full of sludge. It's "low-spot" location kind of invites that... I installed a new sender and all was fine.
Old 02-28-2011, 02:01 AM
RPetty
RPetty's Avatar
WOW,
that 14 PIN Configuration is different then my sons. ('87)
I guess as long as the proper posts line up, its ok
Old 02-28-2011, 04:06 AM
Bill Ball
Under the Lift
Bill Ball's Avatar
Yes, for all the years I've looked at, it's pins 3 (blue/yellow) and 5 (blue/green).
It can be fun to figure out the correct configuration of that connector if it comes apart and the pins fall out. The connector wiring is not shown in one place in the WSM wiring diagrams, but parts of the connector, which is designated T18, are scattered over a number of sheets. Plus the wire colors can fade quite a bit over the years from exposure to the elements.
Anyway, 87-88 are the same. 89+ has an additional wire (pin 7)
TOP (male pins)
PIN - WIRE COLOR/STRIPE - Function
1 - Blue - alternator exciter
2 - Blue/Black - oil pressure
3 - Blue/Yellow - coolant temp
4 - Blue/White - oil pressure
5 - Blue/Green - coolant temp
6 - Green/Blue - oil level
7 - EMPTY except 89+ Brown/Red - oil pressure
8 - EMPTY
9 - Black - AC compressor clutch coil
10 - Green - intake air temp switch for fans
11 - EMPTY
12 - EMPTY
13 - Brown - intake air temp switch for fans (ground)
14 - Yellow - starter solenoid
The BOTTOM (female pins) differs at:
7 - 89+ Brown/Green
10 - Brown/Blue
Jim's pic shows an 86. The 85/86 connector differs in:
7 - Red/White - auxiliary air valve
10 - EMPTY (in 12 instead)
12 - Green - intake air temp switch for auxiliary fan
13 - Red/Green - intake air temp switch for auxiliary fan
and top and bottom wire colors are the same.
Old 02-28-2011, 04:49 AM
Tony
Tony's Avatar
hmmm..Where is this 14 PIN connector located?
Old 02-28-2011, 05:13 AM
993turbo
993turbo's Avatar
How about the wire for the cam belt tension warning on 85 models' and later......
Quick Reply: Did the 14 pin connector..ah geesh..
