Fitted or regular heater hose
I need to change the small hose running from between the radiator hoses on the thermostat housing to the pass. fender. Is it molded or just regular heater hose? I've been all through section 19 of the manual but can't find any reference.
Fitted.
The ends are the right size...normal hose, is a fight I found.
http://www.autoatlanta.com/porsche-p...-91/105-05.php
Chronic Tool Dropper
Hmmm... I think I used 5/16" (8mm) hi-press fuel hose for the vapor vent lines. One from the water bridge, other from the little nipple on the radiator tank. Used a black Magic Marker to hide all the writing on the hoses so it would look OK on inspection. The hi-press FI hose is more than up to the task, and readily available at most POLAPS.
