928 Forum 1978-1995
Sponsored by: 928 Specialists
AC compressor shopping
Old Feb 20, 2011 | 01:57 PM
Ducman82's Avatar
Ducman82
Veteran: Air Force
Default AC compressor shopping
Anyone have a good source to get a reman AC compressor for an 81?
Duc
Old Feb 20, 2011 | 08:56 PM
Ducman82's Avatar
Ducman82
Veteran: Air Force
bump
Old Feb 20, 2011 | 09:10 PM
Rob Edwards's Avatar
Rob Edwards
Archive Gatekeeper
http://www.mailordercentral.com/928i...26%20010%2006R
I'd just get one from Mark, there's so much confusion from non-928 vendors about what fits what year with which clutch and which pulley. Google '928 porsche 6E171 compressor"' and look at what years various parts places quote as needing a 6E171. Most of them get it wrong.
Old Feb 20, 2011 | 09:56 PM
Ducman82's Avatar
Ducman82
Veteran: Air Force
right on Rob.
Old Feb 21, 2011 | 12:07 PM
dprantl's Avatar
dprantl
If your 6E171 is not totally busted up, you could try rebuilding it yourself. The one I did many years ago on an '86 still works today. Seals cost ~$30 at most.
Dan
'91 928GT S/C 475hp/460lb.ft
Old Feb 21, 2011 | 12:08 PM
Ducman82's Avatar
Ducman82
Veteran: Air Force
mine is not leaking, the clutch rubber part, melted......
Old Feb 21, 2011 | 12:20 PM
Rob Edwards
Archive Gatekeeper
If all you need is a 6E171 clutch, maybe you can find a match here:
http://www.polarbearinc.com/PBPC/hom...ensions_1.html
Old Feb 21, 2011 | 01:01 PM
jwillman's Avatar
jwillman
Is there a way to test the clutch and or compressor? The compressor belt was off when I bought my 79 and PO had no history for the short time he had it. I have since pulled the compressor and have it in the garage. I also got a spare part box with the car that has another compressor that I also have no history on other than it is much cleaner than the one on the car.
Old Feb 21, 2011 | 01:08 PM
Ducman82's Avatar
Ducman82
Veteran: Air Force
thats a good question. im not sure if the rubber failed due to the compressor ceasing, or just weak, old rubber.
Old Feb 21, 2011 | 03:02 PM
JoeTaylor's Avatar
JoeTaylor
Hi Duc,
I bought a AC Compressor for my '88 from http://www.techchoiceparts.com/
The rebuilt compressor was $224 (no exchange required) and a new reciever/dryer was $15
Had it all installed and recharged, everything works great.
They do the rebuilds inhouse, so you might want to call them and see what they can do for you.
Joe
Old Feb 21, 2011 | 04:27 PM
dr bob's Avatar
dr bob
Chronic Tool Dropper
Duc--
There is no 'rubber part' of the clutch. There is a friction surface that gets pulled into a flat metal face by the magnetic coil. Usually, if you see something that looks like rubber, it's melted insulaton from the clutch coil itself.
