Sunroof noise?
Sunroof noise?
MY 1981
I reworked the sunroof and it is now operational, yahoo and I couldn't believe I did it myself, well a little help. Mostly dismantle, clean - re-grease and replace.
Question: Does anyone else think the wind screen deflector is noisier than if it was removed? I removed mine and not only opens up the view but is a lot quieter. What you think? Anything I'm not seeing here?
It does not close like it should exactly but I think close enough. I like quiet and more view.
I noticed the same with both my '86.5 and '81. What I did was 'de-spring' the deflector. Not remove the spring, but bend to allow deflector to come down easier. As is now the faster driven the more the deflector drops. Also notice the sunroof closes a bit easier this way.
MY 1981
What is up with the 2 large spaces in the rubber gasket? Would this not just let more water in? I see the drain holes but holy smokes a little less open space seems to be a better way to go. Just sayin.....
Had a great 3 hour ride along the Mt Laguna ridge 3 times last Thursday, beautiful southern california day. Practice, practice, practice.
I like the no deflector look.
I have been working on my car since October and it has a way to go before it is dependable. Fun working on it.
I did away with mine with no regrets... of course, keeping all the old parts, just in case.
BTW - San Diego, maybe an optical illusion, but it the bottom pic it looks like you may have both rear wheels on the driver's side and I'm guessing your fronts are on the other side.
Ken
80 928 S
5 Speed
UK
Tech Bulletin
MY 1981
A slight amount of can make a huge difference in wind noise...
I did scan that template in a long time ago and will see if I can find it...
Mark
One of the "Tech Bulletins" has a board like page on which Porsche has printed a template that you can cut out to set the angle of the deflector to the factory specs.
PS: I had my hen remove her teeth for obvious reasons, don't know where they are now either, haha...
