928 preformance cams reviews?
i'm considering getting some 928ms cams, does anyone have these and what are the gains? other options as far as vendors.
Looking for a little more power fot my 91 s4.
Rest in Peace
I had to go to aftermarket RHS ported heads, slightly bigger headers, smaller converter, and a larger ported intake, just to go up a little on the cam size.
It all has to work together or you are just throwing your money away.
I could not tell you how many engines I see that have way to much cam for the car the way it is set up.
A big duration and large overlap cam is not going to work well in a car with a tight converter and stock heads.
Nothing cheap about going fast, and nothing cheap about going anywhere at any speed in a 928.
HCI, heads, cams, and intake all need to work together, but I would still like to hear of some people with experience using the various "optional" cams that are available for the 928.
Cams can have a good impact, but you're better off doing headers first (better than an X-pipe), so that you get the breathing benefits from the cams.
See this thread for a very nice 5.0L rebuild that included cams.
https://rennlist.com/forums/928-foru...and-video.html
Mikes Cams are a thing of beauty like everyrhing he does. Simply amazing.
Cam's, head work, headers and install if you do not do it has to be about 7k worth of work. Just a guess.
Go with Colins (Lizard) or Simards cams.
You'd be much better off with a full exhaust.
