PKlamp and Super Clamp
#32
I had the stock set-up replaced with the Super Bearings and Super Clamp over 15 months ago. in January I had that "rattle" noise in the TC area and replaced the rivets with bolts. No more rattle. Also checked for any movement at the front. Zero. Constantine's products are rock solid and take care of the one of the two most butt puckering issues we have with the 928....Timing belt and drive shaft/flex plate movement.
I also have the PK tensioner and highly recommend it as well. Any stretch with the new belt will automatically be corrected and "loose belt cam timing skips" on cold starts are eliminated as well.
Great products from Master craftsmen.
