What mods have you done to your shark?
#48
I'll let you win Jim.
AO
AO
#50
Official Bay Area Patriot
Fuse 24 Assassin
Fuse 24 Assassin
Suspension & Steering
1. Externally Adjustable Koni's, Eibach Springs
2. Ott Drop Links Front & Rear
3. 928sRus Rack bushings
Engine, Exhaust:
1. 6.4 liter stroker with Oliver Ti rods, lightwieight wristpins and JE Pistons
2. Spec Lightweight flywheel
3. Spec stage 3+ dual disk clutch
3. 928 Intl stepped headers - modified
4. Custom dual 3" stainless exhaust with Borla XR1 Race mufflers
5. Variocam - Billet cams
6. 968 Intake valves
6. 36 Lb. injectors
7. 928s-R-Us intake spacers
8. Ported cylinder heads and intake manifold
9. 4mm Over bored throttle body
10. Porken Tensioner
11. Provent Air/Oil separator
12. Carbon fiber strut brace
13. Custom oil fill cap
14. Intake manifold and cam cover re-paint
15. custom painted engine letters
16. 968 Cam covers
17. Modified air cleaner air box
18. Motec M48 Pro ( stand alone fuel injection and ignition computer)
19. Rising Rate Fuel Pressure regulator
20. Bosch 044 fuel pump
21. Custom aftermarket Harmonic Balancer
Interior:
1. Paul Champagne custom Sport Seats
2. Custom door panels for 6 inch speakers with Paul Champagne leather.
3. Paul Champagne Head liner
4. Paul Champagne Rear Quarters
5. Dual custom extinguisher bracket with extinguishers
6. Nakamichi Mb75 with MB70 disc changer
7. MBQuart 3 way door speakers
8. Alpine Amp & EQ
9. JL Audio 10w6 sub with custom Fikse Wheel grill
10. Rear Seat delete with custom storage compartments & tray
11. HomeLink/compass mirror
12. Valentine 1 radar detector
13. Custom Mahagany colored GTS Shifter
14. Short shifter kit
Exterior:
1. Fikse FM10 18" wheels 9” front, 12” rear ( 265/35 F, 335/30 R)
2. Bosch H4 headlights with 80/100w bulbs
3. 43 Bar Brake Bias valve
4. Front cast hole rotors
5. GTS calipers (f)
6. Rear cast hole rotors
7. Deleted rear wing
8. Deleted rear wiper
9. Deleted headlight washers
10. Deleted side markers front and rear
11. Rub strip delete
12. Clear front turn lenses
13. Deleted front bumperettes with Euro filler panels
14. Window tint
15. Dynomat sound proofing
16. GTS mirrors
17. Widened GTS rear Quarter panels
18. Stainless door sills
Drivetrain:
1. Auto to manual conversion
2. stage 8 locking halfshaft bolts
3. 2:20 trans with LSD
Have the parts for but not installed:
1. Ott ITB intake system
2. 75lb injectors
3. Simard Racing billet gun drilled cams
4. Motec M48 Pro ingition expander
Planed but not started:
1. F50 front brakes
2. 993TT rear brakes
3. Carputer
Engine, Exhaust:
6. 36 Lb. injectors
16. 968 Cam covers
Interior:
8. Alpine Amp & EQ
Exterior:
5. GTS calipers (f)
14. Window tint
16. GTS mirrors
Drivetrain:
2. 75lb injectors
1. F50 front brakes
3. Carputer
#53
That actually sounds quite practical. I had visions of an oil/grease reservoir installed into the spare tire well for strategic and timely release onto the path of approaching bandito's.
The CHiP's are starting to incorporate the use of the laser out here. For years they've just driven around with the K-band on...full time. The V1 picks them up miles in advance. The laser is a different animal.
Thx. I'm going to look a little more into this laser jammer business.
#54
Look into Laser Interceptors (#1), or Blinders (#2), but skip on the Escort Zr4 or Zr3's. When I get to the point that I don't need to spend money just getting/keeping mine running correctly, the LI's will be my next upgrade.
#55
#57
Supercharged
I have the Blinder M25. I think the new unit is a the M27. This only provide for front laser coverage. You'd need to step up to the M47 (4-heads) to get front and rear coverage.
#59
Oh you were recently in the hospital, what was worked on? Oh nothing much. Had a little cut on my arm and they put a bandaid over it, scrape on the knee and they cleaned that up. Had a Super Atomic Bionic Heart put in. Nothing much.
#60
Not much left to modify.
Engine:
Chassis:
Engine:
- Morton Engineering Stage 2.5 intake manifold porting
- 928 R US intake manifold spacer
- Morton Engineering Stage 3 valve seat modification
- Porsche 968 intake valves (39 mm)
- Morton Engineering Stage 2 reground cams (greater lift & duration)
- Morton Engineering Stage 2 Sharktuning
- Kao Racing Stage 2.5 cylinder head porting
- Heads shaved 0.020" for 10.4:1 compression ratio
- INA lightweight hydraulic tappets
- 91 GT block, crank, pistons and rods
- New main bearings w/ 227º grooved thrust bearing
- ARP connecting rod bolts
- Crankshaft drilled by Taylor Engine
- Porkensioner
- Gates racing timing belt
- Hi-Torque lightweight starter
- Ishihara-Johnson oil control kit
- Mike Simard 3/8" oil pan spacer
- Mike Simard oil pickup spacer
- Revised oil breather system
- 2 qt Accusump w/ oiling take-off directly from the block
- GT oil cooler
- Devek Level 2 headers w/ 1-5/8" primaries
- 3.5" single exhaust w/ two Borla XR-1's
- 3.5" Laguna Seca pipe turndown w/ Supertrapp
- Adjustable fuel pressure regulator
- Ford Motorsport 24lb/hr injectors
- GTS fuel pump
Chassis:
- Kinesis K58 3 pc wheels (10"x18"f, 11"x18"r)
- Nitto NT-01 tires (275/35/18 & 315/30/18)
- Custom fabricated anti-roll bar mounts
- Devek racing front anti-roll bar
- Modified rear anti-roll bar w/ adjustable connection points
- Devek Rollbar
- Recaro Pole Position passenger's seat
- Recaro SPG driver's seat
- TRW 6-point harnesses
- Momo Competition steering wheel w/ Sparco 2" hub extension
- Bilstein dampers with custom valving
- Morton Engineering Stage 1 spring hats
- Hyperco springs (800 lb/in f, 550 lb/in r)
- Porsche 993 Twin Turbo Big Red Calipers front AND rear
- Porsche 965 cross-drilled 322 mm rotors f, 304mm r
- 33 bar bias valve
- Pagid Orange pads
- GTS clutch
- Morton Engineering Stage 1 steering rack solid mounts & extra stops
- 78-86.5 lower front control arms for extra camber
- Devek/Ron Davis Racing radiator
- Custom fabricated aluminum front splitter
- Fire extinguisher
- Gutted rear interior and door panels
- Air conditioning system removed
- Stereo removed & replaced w/ 928 Club Sport faceplate
- Modified limited slip differential ~60% lock
- Devek engine compartment brace
- Odyssey PC-680 racing battery w/ custom battery box mounting
- Shorter ratio 2.64 5-speed gearbox
- Pinned Weissach axle
