S4 fuel cooler..how?
Now lets think about this. Your AC use's HP to run, but the cooler fuel allows more fuel to enter so really the HP is made back. Very Smart.
I would think that in the soutern states where it is very hot in the summer, it may stop the fuel from getting to hot.
Now if I am not mistaken, it is on the return line to the tank. That is the one thing that makes me wonder why?
Why not on the pressure line?
Well, the A/C is on with defrost..so theres little interest in cooling the IN fuel in winter..but you still have VERY hot fuel on the return line.
Thats all I can come up with..just it fits the bigger picture better, on the return.
The cooler is not on the pressure/feed line because that fuel has not been heated yet. The idea of the cooler is to remove the heat that was added to the fuel by passing through the hot engine compartment, particularly under extended stop-and-go idle conditions.
Received 1,605 Likes
Helps prevent vapor lock (or so I hear).
The internals of the fuel cooler are actually a lot more complicated than I anticipated based on how innocuous it looks on the firewall.
Its designed to keep fuel temps in the tank down on hot days (i.e. when you'd need AC running) - presumably to reduce knock, and/or cavitation at the pump.
If you do a search, there's at least a couple of guys chasing big hp who've had fuel temperature issues (George's supercharged Open Road Racing car comes to mind) on their custom fuelling setups.
