Almost no fuel to injectors suspect fuel distributor
#47
Ok I will check cold start tomorrow right now my car is hydra locked with fuel. I Pulled out an injector and jumped the fuel pump at first no fuel came out so that is good and then when I pushed on the air meter door fuel sprayed out of the injector in a nice conical spray pattern and increased as I pushed the door down when I let go of the door fuel instantly stopped flowing. So it appeared to me that the fuel distributor is working properly. But now there is so much fuel in my oil that I have to change it again I mean there is so much fuel mixed with oil it is pouring out of oil breather when I try to start. Tomorrow I will check cold start and turn a/f mixture cc to lean.
#48
I need Help anyone who is from Portland OR Camas WA Vancouver WA or anywhere close by that really truly knows these 1979 928 CIS engines please pm me I will pay for help of course and your gas. You can email me at justinrking1@yahoo.com
