Need radio antenna cable with amp (88), broke mine!
Pulled the end off of the cable when I was pulling the radio out (crap). Not a normal coax cable. Center wire must be wound around the inside of the insulator to get the propper length.
Does anyone have a good cable and amp they are willing to part with?
Thanks,
Glenn
Thanks,
Glenn
The Parts Whisperer
If you are loking for the din cable it is standard so a good radio shop should have it
Almost Deleted
Glenn, I believe this should work. Its a solder-less antenna connector for DIN-style antenna's.
http://www.radioshack.com/product/in...ductId=2102835
Problem is I pulled out the center conductor from the cable, it came out a good foot from the end but still attached. The wire is very thin and must be wound for the proper length.
Tom,
I can solder the antenna coax cable to the to the amp if the cable is good.
Thanks,
Glenn
Tom,
Thanks,
Glenn
