driver side marker lights dont work now. ????
There are two fuses, one left and right for the side marker lights. both are good. ( swapped the right for the left and the driver side still doesnt illuminate) why else would both (f/r) side marker lights be out. all the lights work, except for those. any other places to look that might be a problem?
thanks,
thanks,
Team Owner
a little bit of perusing and you will find this.
https://rennlist.com/forums/928-foru...asher-out.html
I will bet you have a similar issue,
as always what was the last thing you fixed?
got power to both . both bulbs went out at the same time???? reallly strange. Ill have to check the bulbs. how do the bulbs come out anyway? from the rear, or do you have to take out the assembly?
how does it come un clipped ? I see the two wires with spades, but I think they dont even need disconnecting, somehow, the inside comes out, right?
