928 Forum 1978-1995
Sponsored by: 928 Specialists
MAss airflow Sensor
Old Jan 15, 2011 | 05:53 PM
Reds4Indiana's Avatar
Reds4Indiana
Default MAss airflow Sensor
okay, maybe an easy question.
What would the symptoms be of a bad mass airflow sensor? If you look down inside the sensor, under the metal screen, there is the center part, then the outer part. the outer has small wires in a circle around the center. One of those wires (looks like a light bulb filament) is broken on this one.
Would that cause the hard to start (have to press gas in to make it start) condition? Also would it cause the acceleration or lack there of when advancing the throttle?
thanks.
Old Jan 15, 2011 | 06:38 PM
Stromius's Avatar
Stromius
Yes! I had mine rebuilt by injectionlabs.com but others here on RL are very qualified to rebuild. JDSPorsche.com has US/Canadian based affiliates. See site for FAQ on the MAF.
Old Jan 15, 2011 | 07:11 PM
John Speake's Avatar
John Speake
What you see is a broken platinum hot wire, it should have 3 sides visible. Louie Ott in OR has my rebuilds in stock, see my website for his contact details. Or PM louie928
Old Jan 15, 2011 | 07:43 PM
jleidel's Avatar
jleidel
Almost Deleted
Roger at 928sRUS usually has rebuilt units in stock as well. I just replaced mine with a rebuilt unit and it worked like a charm...
