928 Forum 1978-1995
Sponsored by: 928 Specialists
oh brother!
Old 01-16-2011, 06:27 PM
Landseer
Landseer's Avatar
Can you post some pictures of the engine bay and the intake tubes?
There are actually 4 different sets of 16V tubes.
(The high-hp cars have the larger diam versions)
Lots of nuances in intakes between the various 16V cars.
Here's my attempt to summarize:
(one other note: don't substitute the L-jet barbed injectors into the Euro LH-Jet car. The impedance difference can fry the LH-jet computer per this thread https://rennlist.com/forums/928-foru...rs-beware.html)
Old 01-16-2011, 06:29 PM
RFJ
RFJ's Avatar
Default small tubes?
What karl says makes more sense than anything but HP ratings would maybe off. will find out when i get it running again,be a while back operation tuesday, take 3or 4 wks after that. Best to you ,Ray
Originally Posted by karl ruiter
I also think that they used the smaller diameter intake tubes on the last of the euro 16V cars. It this is correct the reason would be that they needed intake tubes that would accept an electronic injector rather than the CIS injector, so they used the intake tubes they had been using for the US L jet cars. They probably felt that the smaller diameter would not have a big enough impact in performance to merit designing new tubes for these last couple of years of 16V production. And based on the published performace numbers, looks like they would have been right. It is possible that there could have been a 'using up stock' factor too, but then that might be the reason why they stuck with 16V motors for these years when the US cars were already 32V. Or perhaps it was just because the US 32V motors were still not making as much HP as the euro 16V cars.
Old 01-16-2011, 07:33 PM
RFJ
RFJ's Avatar
Default intake tubes
will try to get pics up? numbers are crazy,block m 28/21 heads 104 348 runner#1110681 t/b 110230. what can i say thats it.What do you make of it? thanks,
(one other note: never substitute the L-jet barbed injectors into the Euro LH-Jet car. The impedance difference can fry the LH-jet computer)
Old 01-16-2011, 07:38 PM
RFJ
RFJ's Avatar
Default T/B
so if i can't find the right t/b would it be possible to use an s-4 t/b? your humble servant., Ray
Old 01-16-2011, 08:45 PM
Landseer
Landseer's Avatar
Well, the intake runners look correct for the 85 Euro.
The throttle body number you mentioned doesn't make sense to me for a 928.
How could a MAF even be used on the car if it doesn't have the 84/5/6 Euro S throttle body and air guide?
What triggers your concern, Ray, about possibly having a small diameter throttle body? Maybe your car is has it and is ok?
Old 01-16-2011, 08:51 PM
hacker-pschorr
Administrator - "Tyson"
hacker-pschorr's Avatar
Received 2,169 Likes on 1,226 Posts
What makes you think that is a US intake? That's the same part number on mine and I know for a fact it's a larger ID than my L-Jet runners.
There are so many subtle differences between the L-Jet and EuroS intake, I'm having a hard time believing any EuroS left the factory with a modified L-Jet setup.
Old 01-16-2011, 08:58 PM
soupcan
soupcan's Avatar
My 85 Euro S intake part numbers
Intake runners
928 110 681 1R x 2
928 110 682 2R x 2
928 110 683 1R x 2
928 110 684 1R x 2
Plenum
928 110 159 0R
Elbow
928 110 199 3R
TB
928 110 530 0R
Old 01-16-2011, 09:01 PM
Landseer
Landseer's Avatar
Thanks for those numbers, Brian, I need to revisit/reconfirm my chart (pulled them from PET's)
Old 01-16-2011, 09:08 PM
James Bailey
James Bailey's Avatar
Note that the numbers on parts are almost NEVER the Porsche part number.....casting numbers subassembly, supplier part numbers, but seldom the actual Porsche part number....
Old 01-16-2011, 09:20 PM
Landseer
Landseer's Avatar
Ahh.
Well, the runners in the pictures match up to the "R".
Plus Hacker has them on a Euro.
And they are the exact intake tubes on Jadz928's 84 Euro which I just confirmed.
And they are totally different than the 84 USA L-jet tubes I'm looking at right now.
So maybe there is no problem!!!
Old 01-16-2011, 10:02 PM
RFJ
RFJ's Avatar
well your info looks good and i thank you for that, it was pictures of larger intake tubes and Mark K talking of t/b's with an id of up to 3.5 inchs that really got me going and i will continue to look until i find out.If and i mean IF my car really makes 310 crank hp then imagine what the larger runners and t/b would do or maybe i am dreaming, i don't think so. thanks, Ray
Ahh.
Old 01-16-2011, 10:12 PM
soupcan
soupcan's Avatar
The Euro S 'with the larger runners' makes 310, there is a number of dyno day in the next month in SW Florida to find out what you have now.
Old 01-16-2011, 11:36 PM
RFJ
RFJ's Avatar
Smile t/b
thank you Brian, would you know there size and also the size of the t/b and where to find info on same? AS far as dyno in the next month- back operation on 1-19-11 and i would at least a month before i do anything, nevertheless very interesting i had no idea, thanks, Ray. would still like to know if s-4 t/b's would fit on an s-2. thanks
Old 01-16-2011, 11:49 PM
soupcan
soupcan's Avatar
S4 TB is different, won't interchange. The euro s TB is 3.4 diameter if I remember.
You have the best 4.7 combo.
Old 01-17-2011, 01:32 PM
RFJ
RFJ's Avatar
Thumbs up t/b
Thank you i am maybe making noise over nada just would seem it should be larger, will work on that. thank you, Ray
Quick Reply: oh brother!
