Need Info: 82 Euro S specific fuse/relay chart
Chris
My Euro 82S 5 Speed does use the XIV relay as pictured below with a red cross on it (It's a 40A relay). In my owners manual it lists XIV as ... Bridge (automatic gear box starter relay) and doesn't show a relay in the pic, but also doesn't show a bridge. Therefore it would seem that the auto has a bridge and the manual has a relay ... I wonder why.
ok- I figured out that the pins have numbers next to them and I have the start bridge relay XIV jumpered 86 to 87. (I don't know how to read the diagrams on the sides of the relays very well) Now what do I jumper on the fuel pump relay(XVII) to get some fuel through the line for a flush? I have relay 92861511301 in there and it looks and smells good but the fuel pump is not coming on when I turn the key to ign. I have had the fuel pump working in the past by powering at the pump itself. It looks like the panel is a little brown behind this relay but no new damage.
Chris
Have you cleaned the fuse contacts?
They are sensitive to corrosion.
And the fuses can burn through and you can't see them, but only feel it.
Thanks Dave!
What this young man has done to transform this car is freaking amazing.
(pelican)
He has been using a lot of patience as it is almost ready to run.
Thanks Dave!
(pelican)
Chris
Thanks Dave!
(pelican)
Thanks Dave!
(pelican)
Andrew Olson's list of owners manuals hosted on google includes an '83 Euro S owners manual in PDF form. '83 was the same K-jet injection/engine as the '82 Euro S.
https://rennlist.com/forums/928-foru...al-online.html
Do some manual 928s get a switch on the clutch pedal?
I'll post the pics to show why I valiantly went 0-40 in disagreements with Wally. Or did I?
Rennlist Site Sponsor
Dave,
"My Euro 82S 5 Speed does use the XIV relay as pictured below with a red cross on it (It's a 40A relay). In my owners manual it lists XIV as ... Bridge (automatic gear box starter relay) and doesn't show a relay in the pic, but also doesn't show a bridge. Therefore it would seem that the auto has a bridge and the manual has a relay ... I wonder why."
Perhaps easy to misunderstand this. Since you have a five-speed, your manual is in effect saying, "Your five speed has a bridge here, but the automatic gearbox has a starter relay."
All early automatics have a start relay, all early five-speeds have the bridge. Later, Porsche changed to a start relay on all cars. On those later cars, the relay coil on the automatics is grounded thru the park/neutral safety switch; on the five-speeds, the coil is hard-grounded.
so what should the starter relay be jumpered on then? 30 to 87 turns starter immediately key in or not. What should it be jumpered to to only turn starter when key is turned to ignition cause nothing happens when ignition turned on 86 to 87. Gunar
Remove the wire.
Take your voltmeter and check 86 to ground, without and with, ignition key.
Lets identify 86 that way.
30 is always hot.
86 is from the 15 bus according to the diagram above, so its hot only with key.
30 is always hot.
I'll tell you what I recall...
The bridge for a 5spd is like an "L" or "T" where the two tangs are a right angle. Looking at the pics, it's gotta go as in the linked pictures you posted. Is that where it comes on immediately?
I'd run out and look but there's no 928 in the garage.
