Anti Seize & Electrical Conductivity
While cleaning the ground points I wanted to add a bit of anti seize to the bolts on reassembly - especially in the lower engine. I know that the copper anti seize is electrically conductive (says so on mfg site), but the "grey" anti seize (http://www.permatex.com/products/aut...ubricant_a.htm ) makes no mention of electrical conductivity.
The ground strap from the bottom of the engine looks to connect to aluminum (engine side) and brass (frame side) so I am wondering if people use the "grey" (for aluminum) version with success on the ground points.
Also, I noticed that in past service, people have applied a generous amount of antiseize (grey) to the outside of the bolt and the surrounding area. Common practice?
Thanks,
Dave
Thanks,
Dave
Anti-seize is generally a poor conductor of electricity as the metal content is relatively low thus the effective contact area is minimal. Electrically conductive grease might be a better choice?
http://www.cool-amp.com/?gclid=CIbxy...FULNKgodyV6Rnw
If the anti-sieze/grease is doing any conducting you haven't torqued the bolts sufficiently - you will have good direct metal to metal conduction - I wouldn't worry about it... use any type you like.
Alan
Alan
Actually, I am concerned about the opposite...I have had many seized bolts in my car, so each time I have access to one I want to do what I can to prevent stuck bolts in the future. My "favorite" would have to be broken cam cover bolt I had to drill out
