Battery Gauge Resistor - Help Needed
Not sure if its the earlier car or the 87 you are working on, LGL.
Dwayne's 84 odometer thread it shows the back of the foil that should have some similarities to your car.
84 looks to be screw mounted. Yours soldered instead? Gotta fit in those holes showing on your panel. Resistor isn't directional, so it should work in either orientation.
https://rennlist.com/forums/928-foru...re-w-pics.html
Thanks for the inputs. Fix is in the picture. Turned out for my 86 to be non-soldered and snaps in to the edge of the pod and presses down on the connection.
