Optimoly questions
Rest in Peace
I have a newer tube of what i think is Optimoly HT (or its replcement), the part number is 00004302400.
Any body have a idea about this?
Rest in Peace
Not the first time I have had this question answered, but at least this time I will have a thread to come back to for the answer.
Archive Gatekeeper
The Optimoly HT I have is is 000 043 004 00. Thick stringy copper antiseize-y looking stuff for your intermediate shaft, PP fingers, etc.
Greg used half a tube of 000 043 024 00 in rebuilding the GTS tranny, for whatever that's worth. Maybe 000 043 024 00 is the current # for Optimoly HT?
The part # that got me Optimoly TA in 1/09 was 000 043 020 00
Drei Bond is 000 043 203 73
Porsche caliper paste is 000 043 117 00
Rest in Peace
i have the TA and the above, and some place i have another tube, maybe Porsche in atlanta will have some in stock.
so why can't I use just silver anti seize on my block water drain plugs instead of copper anti seize?
sweet, so the silver stuff won't affect my block water drain plugs. perfect
Rest in Peace
Central Shaft I
The first version of central shaft 928.421.235.12 (no longer available) was sometimes
installed together with new clutch parts.
The modified central shaft 928.421.235.13 was replaced with central shaft 928.421.235.16
(hard nicle-plated/same size) as from June of 1983. Central shaft 928.421.235.13 will no
longer be available after depletion of stocks.
Axial movement of clutch discs on central shaft I is better after long operating time when
using the hard nickle-plated version in conjunction with the specified lubricant.
Identification: 928.421.235.13 gray/black
928.421.235.16 dull silver
Lubricant specifications for splines (central shaft I and clutch discs):
928.423.235.12 and
928.423.235.13 very thin coat of Optimoly HT
928.423.235.16 coat of Optimoly Olista Longtime 3 EP
(Part No. 000.043.024.00)
From the WSM, looks like I have the right stuff for the nickel shaft, which I think I have, this is hard to try to piece a clutch together correctly with parts from all over.
928.423.235.12 and
I strongly suggest you acquire and use the copper(looks gold in color) stringy sticky stuff as called for originally for the clutch intermediate shaft and pp fingers otherwise you may find yourself back in to the clutch within a year or so because other lubs will break down and dry out. I don't have the part # handy.
Rest in Peace
I have this, Optimoly Olista Longtime 3 EP (Part No. 000.043.024.00)
I am going to laugh if this keeps up.
Rest in Peace
OPTIMOL HT Paste
000.043.024.00
$14.46 plus shipping. Buy something else to spread the shipping cost!
www.928gt.com
Note that the new clutch guide tube and sleeve for the single disk clutch have a plastic sleeve and should not be lubricated.
000.043.024.00
www.928gt.com
Received 1,589 Likes
Wally's post refers to the fact that a GTS guide tube and t/o bearing do not get LongTime EP lubed ('cause the t/o bearing has teflon (IIRC) pads on the inside.)
The original pre-GTS bits did (and do) get lubed-up. And no matter which version, the splines on the i-shaft need the high-pressure Opitmol(y) grease (along with whatever else the WSM calls for.... ends of the fingers on the PP?... I think.)
