Electric Fan System For Sale ***UPDATE***SOLD***
Before I list on flea bay I am offering my twin electric fan setup. I removed the mechanical fans and installed this Dave Lomas setup. Has 2 Perma Cool PRM-19114 fans rated at 2950CFM mounted in aluminum shroud and Flex a lite 31165 controller that has temp prove that pushes into the radiator fins.
The controller brings on the fans at approximately 175 degrees at 60%, 10 degree rise in temp will run fans at 100%. Wired to connect to jump post and ground at the radiator mount bolt. You just need to run a switched 12V supply and a wire to the AC clutch wire as the controller will run the fan when the AC is switched on.
![](https://rennlist.com/forums/members/glen-mccartney-albums-cooling-fans-picture8846-928-fans.jpg)
![](https://rennlist.com/forums/members/glen-mccartney-albums-cooling-fans-picture8847-928-fans-1.jpg)
$250 plus shipping
$250 plus shipping
Been on the car for about 2 years, just going with different setup that will give me a little more room up front. This system will handle cooling needs, ran it in 100 degree weather in traffic with no issues, never got to second line on temp gauge.
You would be surprise how hot the summer here is.
I live in the place that has among the biggest difference of temperature between summer and winter. (And the car isn't going out in winter!)
But I admit, nothing compared to nevada.
I just want to remove the mechanical fan. Removing some load on the crank.
