Empty shell to finished car
#136
There is both a fresh air system and a vapor recovery system. At least on the early cars the fan ran at a low level all the time to prime the fresh air system. Where is the other end going?
#138
Thanks guys!
Took another look at the tube this morning, and it is only about 4 inches long, connects no nothing. It is mounted inside a circular bracket that is welded to the inner b-pillar. It is not interfering with anything, so I think I will leave it alone
An early Easter Egg from Porsche?
On a different note, are the rear wheel hubs on the GTS the same size (minus the spacers) as the S4/GT cars? As I am now getting more space for tires with the GTS fenders, I wonder if I can re-use the rear spacers (17mm or 21mm, can't remember for sure) I removed from the rear hubs in order to fit the Fikse FM10's?
Cheers!
Carl
90GT Project
Cheers!
Carl
90GT Project
#139
Funny how time flies, it's been a long time since I had any updates on my project. Life has a tendency to get in the way, and after my company filed chapter 11, and I went through a divorce, I wasn't sure when I was going to get to this point, but today I can say: PAINT TIME!
The car was picked up today, and is on it's way to the paint shop, Visual FX, for some GTS fender grafting, sunroof delete modifications, side-marker delete, rear wiper delete, rear bumperetts delete and door lock delete. Pictures coming again I hope next month.
Cheers!
Carl
Cheers!
Carl
#140
beautiful.
#145
Team Owner
Looking awesome,
what color will this project be?
#146
I hope that this is not impertinent, but its intriguing that a page back in 2012 you said you had a patient wife and now you say you had a divorce. Same person?
#147
Hi Stan,
It will be HoK Jet Black (S2-25) with a blue/ice pearl effect and the
USC01 Kosmic Urethane Show clear coat. Had originally planned a red pearl effect, but I think the blue/ice is more subtle yet creates more sparkle and depth.
Cheers,
Carl
Cheers,
Carl
#148
Love the project. Really excited to see it come together. I have plan to do one like this for my son.
#150
Team Owner
you might consider a cherry pearl or a green pearl,
I did a Blue pearl and its wasnt very noticeable till night time,
when the florescent light showed on it
Check out some of the Range Rover special colors
