Intake Refresh
Thanks Rob for the intake sealing plates. Mucho Gracias, broken taco and all that jazz.
Got an oil splash guard thingy from Mark too. Figured, why not put that in also.
Thermostat and associated seals (all of them) were done by Greg Brown a few year before I bought the car so I am not gonna touch the work of the master.
Got the car up on the lift bars to ease the back stress (though the P90X is the bomb on giving you a stronger core that'll make it easier). Heated garage, lots of room.
I got beer and steaks if anyone wants to come to frigid Iowa and join in the fun! Prolly this weekend is out cause I gotta fly to Northern Wisconsin (oh joy! more cold) and make sure the house up there isn't a block of ice cause my stupid cousins turned off the heat or something.
So XMas is out and new years is out. Jan 8th weekend anyone!!!!
Also consider the "'94/'95 GTS-style dynamic kickdown upgrade" modification while you're in there.
And just replace everything (including the ISV) while it's easy.
Then use HB on the oil fill tube base and on the O ring, this should prevent future leaks'
It also give comfort that the injectors are fully seatedand covers the holes to prevent debris
