Cam Gear Offset
I have some vacation starting next week, and I am going to try and wrap up everything on the car that been unfinished since June. When I put my belt back on this past weekend I noticed the passenger side cam was off the V-mark by something like 1/8 to 1/4 of a tooth - Dwayne's writeup seems to show a similar offset. I did a search on RL, and most threads dealing with teeth offset focus on larger offsets of 1+ teeth.
Is my offset the norm? Or is this something that I should correct?
Also, as an related aside, I was wondering if someone could explain the difference with the cams at their two positions relative to the balancer? For example the cams / cam gears can be in two positions when the balancer is showing 45 degrees or TDC. Also, does it make a difference which you choose when doing work where you need to protect the valves?
Thanks,
Dave
PS -
Photo 1 - Shows engine position (TDC)
Photo 2 - Shows Drivers Side Cam Gear (proper alignment relative to V-mark)
Photo 3 - Wide shot of drivers side cam
Photos 4 & 5 - passenger cam Finding an angle that correctly shows the gear in relation to the V-mark is hard. I hope these two give a good idea.
I also have photos of the cam gears at the 45 degree mark if that helps.
Thank you for your help,
Dave
Thanks,
Dave
PS -
Dave
The 45 degree positioning is just so the pistons will all be down in the bores, thus no danger of a valve hitting a piston when/if the cams rotate. Yes, the cams can be in one of two positions with the crank at 45 degrees. Either position is safe for cam rotation.
If you are changing the belt, you need to mark the cam sprockets at the existing 45 degree position prior to removal for later belt installation. You also need to carefully check cam timing at TDC after belt installation.
Wally is correct about piston position.
However, WSM specifies parking the crank at 45 degrees before TDC#1 for belt removal, and then rotating cams and crank to 0 degrees TDC#1 for belt reinstallation.
So, you don't need to mark the cams if you follow the WSM for reinstallation.
It is the only way to know for sure.
As far a checking the timing now the belt it back on, is this as simple as a visual inspection, or does it involve something like the porken timing device and/or WSM dial gauge method?
Any thoughts on the 1/4 or so tooth misalignment of the passenger cam gear shown in pics 4 & 5 (sorry the photos were not well labeled when I first posted). Is this common? Can cam timing be ok even if the v notches on the gears and back plate don't line up?
Dave
Dave
do a search for liftbars.com
or Roger@928srus.com
Dave
Shameful Thread Killer
The 'offset' you speak about is the slight difference in alignment of the tick mark on the back of the cam gear vs the notch on the backing plate. This is very common. The two tick marks will not line up exactly as its a function of the length of the belt, and the temp of the engine, also affected by the thickness of the head material and even the gasket.
There is nothing you an do about he slight offset. Make sure the teeth are lined up and get the belt on, do the tension and off you go. The only real way to set the exact cam timing is to remove the com covers and use the plunge method on the valve to set the cam location, then install the belt at TDC and secure the cam gear to the cam at that position. The tick marks are simply for the exchange belt service and do not guarantee a perfect cam to crank alignment.
Performing the cam timing is quite a bit more complicated as you must remove the cam cover, or use the Porken 32Vr timing tool which is indexed to the cam flange, and not the cam gear.
Thanks,
Dave
My guess is that of the many cam-belt changes happening, not all are aligned perfect, as suggested (in my mind) by the above discussion. If that's true, there must be some minimal allowable lee-way for installation, right? And if so, what symptoms might there be, if any? Some minor or hardly detectable power loss? Maybe some overheating? I'm just guessing that there are more than a few 928s on the road that don't have perfect cam alignment but the drivers can't tell the difference. Is 928 cam and belt alignment that forgiving. Comments?
All of the ones I do are perfect as far as cam timing, or we do not do them.
But you are correct that many are out of time, the only thing I have seen it affect is idle quality.
As far as the lee-way it is spelled out in the WSM, IIRC it is + or- .1MM at the tappet.
that is not much lee-way.
Dave
