mounting clips on upper interior door trim
The clips look like the same ones used to hold the rear hatch liner on. If so, I managed to reuse my old ones. I don't know if they are available but if so I would think 928 Intl. would have just the clips. Have you tried Roger (see link below)? He is somehow able to come up with P/N's for the most obscure parts.
Basic Sponsor
I have had a lot of luck with using JB weld to put the clips back in place.
They were originally heat welded in place.
I can get the clips if you need them.
![](https://cdn.shopify.com/s/files/1/1694/8685/files/928sRus_rennlist.png?v=1621798567)
Does it have the "Do It Yourself" manual transmission, or the superior "Fully Equipped by Porsche" Automatic Transmission?
George Layton March 2014
928 Owners are ".....a secret sect of quietly assured Porsche pragmatists who in near anonymity appreciate the prodigious, easy going prowess of the 928."![thumbsup](https://rennlist.com/forums/graemlins/bigok.gif)
I have mine off right now and 4 of the 7 clips came off the trim. I removed it to re-glue the leather to the backing. I am using gorilla glue to rebond the leather with what appears to be good results, so I also applied it to the separated clips. I would expect some of them to come off during removal no matter what you use. As long as the trim is held in securely, thats the bottom line.
Ben
Ben
Cottage Industry Sponsor
I have two that keep coming-off. Tried two-component type glue, but it doesn't seem to last - it always cracks at some point. Haven't tried JB Weld - great idea!
