89 S4 cam gear keyway
Hope your garage is heated ![Stick Out Tongue](https://rennlist.com/forums/images/smilies/tongue.gif)
There's a few powder coat folks in Calgary if Edmonton doesn't work out.
Also, the belt tensioner tool in the first picture is now surplus to requirements with the Porkensioner installed...........I'm in the same position.
With the engine out all gaskets are easily replaced...........I'd recommend the silicone oil pan gasket with stud kit and the hall sensor is much easier to access.
Rest in Peace
They are as much a work of art as the clamp is, if not more.
You will be shocked how much more "Beef" there is to them compared to the stock units.
