Hatch release
Hatch release
Hello all
First i have searched but all answers said to replace fuse #26 - 1 amp fuse if motor only turns when switch lifted.
Manual says lowbeam/left 8 amp? Yes all interior light works, door open, i have shimmed and adjusted the arm, only if i understand that 1 amp fuse!!
Barry
Barry
Under the Lift
You don't have the 1 amp #26 fuse. That started in 85. There is an inline fuse near the back, I believe, but I don't know how the 83-4 circuit works. Maybe Alan or some other electrical guru will pop in and provide some electrical guidance and help you make sense of this. Here's a starting place....
Thanks, so the in-line fuse the same as other model 1 amp fuse that cause the problem? I also ordered that rubber hatch insert from Roger so will report back after the RR
