928 Forum 1978-1995
Sponsored by: 928 Specialists
Aftermarket stereo-caused major issues.
Old 11-20-2010, 11:14 PM
Range Rover
Range Rover's Avatar
Default Aftermarket stereo-caused major issues.
When my father and I first drove our GTS (after buying it and having a timing belt change) we stopped at a gas station, filled up, got back in, and the car wouldn't start. The car never would start after it had been running for a period of five minutes or more. Frustrated, we had our mechanic replace the starter...that wasn't the problem, though it did need replacing. We then had the O2 sensor replaced...that wasn't the problem either. We then had the entire computer rebuilt...that wasn't the problem either. Now we are having some wiring replaced that has apparently has frayed as a result of the aftermarket stereo system installed by the previous owner. The stereo has recently been taken out and returned to factory specifications.
I was wondering if anyone had thoughts on this....as if there is anything else that could have caused the wiring to fray as it did. Also, I thought that this would be an interesting read for anyone considering installing a huge aftermarket setup.
-Andrew
Old 11-20-2010, 11:24 PM
Landseer
Landseer's Avatar
Pictures of it would help.
Mice are the usual culprits if the insulation is stripped.
Old 11-20-2010, 11:27 PM
Range Rover
Unfortunately, I don't have any decent pics, as I haven't seen it in person...I've just spoken with my mechanic on the phone...he will email me pics tomorrow.
Old 11-20-2010, 11:29 PM
Landseer
Landseer's Avatar
Stereo installers are just a rung or so away from mice in terms of damage causers.
Alarm installers may be the worst.
Old 11-20-2010, 11:32 PM
Range Rover
Well, apparently this was disabling the alarm and the passenger side door chime. I'm thinking that it's a combination of the lousy installation and the stereo itself.
Old 11-21-2010, 12:02 AM
Ducman82
Ducman82's Avatar
that would have to be one hell of a hack job. did the car crank? turn key and nothing>?>>
Old 11-21-2010, 12:15 AM
Range Rover
It would try to crank, but wouldn't turn over. The stereo was massive...I don't understand why anyone would want so much sound in such a small car.
Old 11-21-2010, 12:20 AM
Imo000
Captain Obvious
Super User
Imo000's Avatar
Originally Posted by Range Rover
It would crank, but wouldn't turn over. The stereo was massive...I don't understand why anyone would want so much sound in such a small car.
That's a contradiction.
Old 11-21-2010, 12:22 AM
Range Rover
Let me rephrase...it would "try" to start but to no avail.
Old 11-21-2010, 12:26 AM
Ducman82
Ducman82's Avatar
so like a slow crank.... sputter and cough???
Range Rover
Yes.
Old 11-21-2010, 12:37 AM
Ducman82
Ducman82's Avatar
hummmm.... if the starter sounds strong, its possible the new gas caused junk to stir in the tank and clog the filter.
Old 11-21-2010, 12:42 AM
Range Rover
Well, it wasn't only that one instance...it happened whenever the car had been on a short drive and then turned off. When I would try to start it again (without waitning 10 minutes) it wouldn't turn over.
Anyhow, the problem is supposedly fixed after four months of trying to figure out what was wrong!
Old 11-21-2010, 12:47 AM
Ducman82
Ducman82's Avatar
crazy! i know mine would not start with out a fight after i first got it. after i parked it when hot it would act liked a flooded car.. turns out the fuel pressure dampener was leaking in to the vac lines and flooding the intake with fuel.... fix that, works every time. and that only happened when the engine was hot.
Old 11-21-2010, 12:49 AM
Range Rover
It is quite frustrating to have a new car that won't start! We'll see what happens on Wednesday when my father and I are supposed to pick it up from the shop.
Quick Reply: Aftermarket stereo-caused major issues.
