928 Forum 1978-1995
Sponsored by: 928 Specialists
Car dies everytime wife gets in the car..
Old 11-20-2010 | 09:06 PM
Speedtoys's Avatar
Speedtoys
Default Car dies everytime wife gets in the car..
88 S4 Auto.
I could say 'WTF' and see what neat theories come up..
But all she has to do is tap on the CE panel cover, and I lose the engine.
All other electrics work fine, just instant complete engine stall.
I dont think its fuel pump relay..that takes a short moment to sputter out...this is instant off engine.
I have a stack of new #53 relays..and its allllmost time to pull the car down for a spell, to do a few things, including the CE panel work.
Just thought I'd pass this fun learning along.
Old 11-20-2010 | 10:16 PM
928mac's Avatar
928mac
Well if you will let me know what it is when you find it, I want to document it and sell it to guys that would rather go for a rip alone.
I might have to mount a kill switch under her seat. he he
Old 11-20-2010 | 10:30 PM
drwhosc's Avatar
drwhosc
lol took the wife for a drive in the mts, points on the 911 burned out. Wife scared the car will get us stranded, re gapped the points, got home put in a pertronixs system, and leave the wife at home now!
Old 11-20-2010 | 10:32 PM
danglerb's Avatar
danglerb
Instant stall, maybe cps?
Old 11-20-2010 | 10:34 PM
Speedtoys's Avatar
Speedtoys
Nah..if she taps the wood over the CE panel in -1- spot, it dies...then its fine on restart.
Kinda funny "Honey...dont tap there, ok?"
Old 11-20-2010 | 10:53 PM
Rob Edwards's Avatar
Rob Edwards
Archive Gatekeeper
The exact same thing happened to S4ordie's '90 near the end of its refresh. Greg ended up pulling the CE panel to discover a PO-bodged FP fuse socket and piggybacked inline fuse holder that was corroded enough to go intermittent when the wood cover pushed on the wiring. Might be time to move that CE panel refresh up the to-do list.
Old 11-21-2010 | 02:12 AM
nosnow's Avatar
nosnow
I'd check to make sure the fuel injection harness isn't getting crushed, pinched, or have a short. The good news is it is reproducable.
Old 11-21-2010 | 07:04 AM
Hilton's Avatar
Hilton
Where is the spot she pushes to kill it? Near the ECU's? Check the ignition monitoring system relay is seated properly (its the clear one mounted on the frame that holds the EZ-K and LH). If that isn't connected, ignition no worky - its the most likely candidate I can think of to cause that, ahead of a really busted up harness from alarm installs as a close second.
If you haven't pulled the CE panel out yet, do it - remove all fuses, clean all contacts, inspect all the wires on the back of the panel, make sure all grounds are bolted to the ground points, etc. etc. - then use a fuse chart to put the correctly rated fuses back into the car too.. chances are a bunch of yours are rated too high due to PO laziness.
Old 11-21-2010 | 07:09 AM
JET951's Avatar
JET951
Hi Hilton , I think from memory the ignition monitoring system is from the 1989 year type ?
Old 11-21-2010 | 07:36 AM
Mike Frye's Avatar
Mike Frye
Craic Head
Try replacing the whole unit and if the new one doesn't cause this problem, you're good.
Wait, are you attached to her?
Old 11-21-2010 | 08:12 AM
Hilton's Avatar
Hilton
Oops, yep correct - I thought the OP had an '89 from previous threads but you're right he has an '88.
Old 11-21-2010 | 12:29 PM
Mike LaBranche's Avatar
Mike LaBranche
Dude, this is an easy one... you have back seats!
Old 11-21-2010 | 01:43 PM
tmpusfugit's Avatar
tmpusfugit
From: Magnolia TX, just north of Houston, Red 1984 S
leave the wife at home. Problem solved.
Old 11-21-2010 | 02:59 PM
Mrmerlin's Avatar
Mrmerlin
Team Owner
remove the CE cover lower wood portion see if one or more of the harness wires are shorted to the CE panel uprights,
this can be catastrophic if left to continue
Old 11-21-2010 | 03:30 PM
Speedtoys's Avatar
Speedtoys
Bout the location of the ignition system relay location, to be specific.
Quick Reply: Car dies everytime wife gets in the car..
