928 Forum 1978-1995
Sponsored by: 928 Specialists
Top Loader gearbox
Old 11-19-2010, 01:46 AM
JET951
JET951's Avatar
Default Top Loader gearbox
Not sure if you boys and girls have seen this yet.
One of the Australian Landshark boys adapting a top loader to convert his auto to manual.
http://928.landsharkoz.com/Forums/ta...c/Default.aspx
Old 11-19-2010, 02:44 AM
RyanPerrella
RyanPerrella's Avatar
thats an old school 4 speed is it not?
WHY ON EARTH WOULD YOU DO THIS!
We now have a new definition of "Franken-Porsche"
Old 11-19-2010, 02:50 AM
RyanPerrella
The end result looks passable, but my gosh, why would you use a gearbox from the 60's ?
I was going to try the same thing with the Tremec T56 from a corvette. Same idea using adapter plated to mount to the factory rear diff in the automatic and I would create a new mainshaft to couple to both the TT and the pinion gear.
Really odd to move the clutch to the back ala 944 also.
I wish this guy would have just used something more modern then he could build a kit and help us all. But no way in hell would I put that transmission in any car.
Old 11-19-2010, 03:23 AM
hacker-pschorr
Administrator - "Tyson"
hacker-pschorr's Avatar
Received 2,204 Likes on 1,243 Posts
My guess would be:
A. Because they work
B. Parts are plentiful and cheap
An M-22 would have been my choice
Old 11-19-2010, 03:30 AM
tailpipe
tailpipe's Avatar
hmmmm now this could be something to considder if i ever get around to putting the caddy 500 in one of the parts cars here awsome job sir and good luck with the rest of your build
Old 11-19-2010, 04:00 AM
9x8
9x8's Avatar
Uhhhh I thought 944 had clutch in the front as well?
Old 11-19-2010, 08:47 AM
FBIII
FBIII's Avatar
I imagine an old toploader can take a hell of a lot more torque than our 5 speeds.
Old 11-19-2010, 11:24 AM
sendarius
sendarius's Avatar
That's where I put the replacement for my broken one.
Old 11-19-2010, 11:31 AM
Ducman82
Ducman82's Avatar
how will shifting work?
Old 11-19-2010, 11:54 AM
Rick Carter
Rick Carter's Avatar
Originally Posted by Hacker-Pschorr
My guess would be:
Q&A from the link
07/07/2010 3:30 PM
Hello There
I tske it the top loader is a 4 speed option? woudnt it be better to choose a replacement 6 speed or at least a 5 speed unit .
In my opinion, and I do not denigrate your engineering ability , the 4 speed replacement is a retro step . I think you could find a market both here and overseas by sourcing a heavy duty replacement unit in 6 speed variety , as there are a few stroker units around with broken transmissions.
Anyway my 10 cents worth .
Best regards
John Gill
07/07/2010 4:41 PM
John, for a highly strung high revving motor with a narrow powerband you are correct and I had a think about that too but you would have to appreciate for my car that I just don't need that many gears. Also for a 928 you don't really need or want a taller 5th gear and most all 5 and 6 speed boxes are overdrive 5th and 6th which would mean you would need a different diff and lose the direct coupled top gear which I think is a great feature of the 928 5 sp.
During my research I found a US drag racing forum for guys with supercharged big blocks and this is the only box they use, albeit a modified one.
One of them had the quote
"If you've got too much torque and want a manual then you need a toploader, If you think you need more than 4 gears then you don't have too much torque."
They all use the close ratio toploader which has a 2.32 : 1 1st gear.
The only reason I use first currently is because if I take off in second with boost and the wheels don't spin it will jump out gear.......with some perturbing bang noises.
The 2.78 first will be smack in between the G28-05 first and second so I can do a touch over 100km/hr in first. The ratio spread is quite nice and top is direct obviously which lets me use the auto diff setup which is really quite clever for mods with its hollow pinion. Also the 4 speed toploader is very similar length to the 928 3 sp auto.
Old 11-19-2010, 12:09 PM
Iwanna928
Iwanna928's Avatar
I think that is a cool option. If one had a lot of torque those tranny's can take it. Milage would suffer but I didn't buy a 928 to get good milage! I am with Hacker, being old school a rock cruscher tranny would be way cool. Hacker needs something like this for his beast!
I wonder how that would work if you had a 5 speed originally and not a auto?
Old 11-19-2010, 12:30 PM
Jim Devine
Jim Devine's Avatar
Looks like a great idea. Once the initial job is done,
parts are affordable & available. If you wanted to
take it to the next level for a track only car (no syncros) you could use one of these-
http://www.jericoperformance.com/wc4rev42.htm
Old 11-19-2010, 12:32 PM
FBIII
FBIII's Avatar
Mileage should be the same. The final ratio on all 928 gearboxes is 1 to 1. None of them are overdrive.
Old 11-19-2010, 01:04 PM
Iwanna928
Iwanna928's Avatar
Even better. Learn something new everyday!
Old 11-19-2010, 06:58 PM
danglerb
danglerb's Avatar
450 ftlb seems to the be the rated torque, but they get exposed to insane amounts and seem to survive.
Quick Reply: Top Loader gearbox
