928 Forum 1978-1995
Sponsored by: 928 Specialists
Another Before/After Detail on an S4....
Old 11-11-2010 | 08:22 PM
Leon Speed's Avatar
Leon Speed
Originally Posted by Marine Blue
Meguiars 205 and 105 polishes which can be used with a Dual Action Polisher.
Here are some links to to the tools I used to achieve the results:
http://www.meguiarsdirect.com/produc...1=MEG+ULTRA+32
http://www.meguiarsdirect.com/detail/MEG+POLISH+1
http://www.griotsgarage.com/product/...dom+orbital.do
http://www.griotsgarage.com/product/...+polish+pad.do
http://www.detailersdomain.com/uberb...polishpad.aspx
It's a multi step process which really does take at least 20 hours to complete. Meguiars 105 is a very strong compound and care should be taken when using it, even with a dual action polisher it can easily burn through edges.
If you're going to buy these items I would suggest buying at least three sets of the cutting pads, I usually burn through two for each car I work on.
Ok thanks, never tried to polish with a buffer and I'm kind of hesitant becuase I fear I'll screw it up, but I'll be doing some research.
Old 11-11-2010 | 08:31 PM
Marine Blue's Avatar
Marine Blue
If your paint looks ok and you don't need major correction I would suggest substituting M105 with Meguiars #83 Dual Action Cleaner Polish. It's not as strong and the abrasives diminish as you polish so it doesn't cut through paint very quickly. You can finish with M205
Old 11-11-2010 | 08:34 PM
Marine Blue
Andrew I failed to mention, my wax of choice is Pinnacle Souveran Carnauba. Two thin coats.
Old 11-11-2010 | 09:45 PM
greg928GTS's Avatar
greg928GTS
Pfffft. Might as well use toothpaste.
The very best car wax is of course Zenith Ascendant Copernicia.
How's it going Af?
Old 11-11-2010 | 09:48 PM
mpesik's Avatar
mpesik
Beautiful.
Haven't seen a RED 928 since 89.
Old 11-11-2010 | 09:52 PM
Speedtoys's Avatar
Speedtoys
Including some light interior detailing it took about 20 hours. A really high level detail can taken 30 - 40 hours.
Im a Gemini, Id give up after about 4.
But wow...
Old 11-11-2010 | 09:59 PM
Speedtoys's Avatar
Speedtoys
The most important part of waxing..is to use the right fabric applicator, with the appropriate cushioned material behind it..so that the wax is applied firmly, but that the cushion also gives just enough to ensure that equal pressure is applied around any curves..err..in the material being buffed.
I use this:
..and you can get the application fabric in matching colors as well.
Old 11-11-2010 | 10:01 PM
Marine Blue
How's it going Af?
Hey Greg.
Never heard of the wax you mention, is it a home made special?
Life is good, can't complain really. I'll give you a call to catch up.
Old 11-11-2010 | 10:58 PM
worf928's Avatar
worf928
Nice work Afshin! It's nice to see that car looking so good.
Wanna show the folks some pictures of the very unique interior?
Old 11-11-2010 | 11:27 PM
Marine Blue
Thanks Dave.
Unfortunately I didn't get any shots of the interior. Definitely very unique and cool Porsche script cloth centers.
Quick Reply: Another Before/After Detail on an S4....
