Supercharged Koenig in Japan
Captain Obvious
Super User
Super User
God this is the 3rd message I have lost on Rennlist since last night.....
Ok Ill start over.
IMHO.... I think the supercharges (all of them) are way over priced.
I think turbos charger systems have to contend with more extreems, way higher speeds and heat and are a little more complext.
I know that there is more to the SC system but in general a blower, some pipeing and Map sensor depending.
I just think that $5000 to $10,000 is way to much IMHO
Ok Ill start over.
Stock they run around 5-6psi. They use a 9th injector triggered by a simple WOT switch. Pretty crude.
Friend of mine has one on a GT, Sharktuned and running around 8 psi. Runs larger injectors and deleted the 9th injector rubbish.
These kits were designed long, long ago. Some spares are still available from Albrex.
There was no way to properly control the fueling until John's brilliant invention came along (thanks John!).
Kits are still available from Koenig in Munich, or directly from the source in Austria from Conrad Gruber, but they are *very* expensive.
Captain Obvious
Super User
Super User
.......IMHO.... I think the supercharges (all of them) are way over priced.
Now, since your signature says you are a mechanic, makes me beleive you should be good to do some fabrication on your own. Therefore, buy a used SC and build yourself the rest for a fraction of the cost. It will take a $hitload of time to make it but, there is plety of information on here to make a Stage 1 steup for not a lot of $$$.
^^^^ What Imre said. The kits available are well engineered and work pretty much as intended right out of the box. It can be done cheaper by doing it all on your own, but it depends on how much you value your time invested and how long you want to have your car down for.
Considering all the time invested, Murf and Carl are not getting rich off of the systems they sell. The volume just isn't there.
