temp gauge not working
Just changed my radiator over for a new one and the temp gauge isnt working.
I did a search but could find any posts on diagnosis.
Any help appreciated
Sam
Sam
Team Owner
the sensor is on top of the water bridge, it is the one that has 2 push on female connectors one is wider than the other.
The other sensor on the waterbridge is a Bosch type this is for the Temp 2 sensor for the computers
Its the brown Bosch connector on the passenger side on top of the coolant bridge in front of the intake (note for US readers, his car is RHD, so your driver's side). Located where the number 4 is on this diagram by Tony (the one shown is the '87 style Stan refers to).
Not to be confused with the blue Bosch connector on the other side which is the Temp II and provides temperature readings to the two ECU's.
Earlier S4's had push-on spade-type connectors, but my 89 has a Bosch 2-pole one.
Team Owner
thanks Hilton
Thanks guys,
Hilton, do you know where the cable runs to ?
Im having trouble seeing where it goes down the front of the engine.
And yes its an 89..
thanks
Sam
And yes its an 89..
thanks
Sam
Team Owner
check the hot post connector and the the 14 pin connector above it
It runs along under the fuel rail cover to the rear of the engine - although I can't remember whether it runs along-side, or is part of, the injector harness.
edit: found a photo from one of my intake refreshes.. its part of the injector harness. Which means it likely has its ground off the rear of the block under the MAF.
