Cam gear seems funny
Maybe just an optical illusion from the bolt. What do you think. Car runs like garbage.
http://www.youtube.com/watch?v=5lsYm9o1pG8
http://www.youtube.com/watch?v=CM3JtK9X9T0
the cam looks like it may be cracked and the bolt is holding on the pulley onto the cam see how the bolt is oscillating it is either bent remove it and roll on a smooth surface and/or the cam snout is busset
what does the timing belt tensioner look like? Is the tensioning bolt torque'd all the way in [such that there is maximum tension possible]? I don't believe an over-tensioned belt should bend a cam bolt like that... but you never know... Hopefully the cam isn't warped!
Looks to me as though it's just the bolt. If you watch the second vid and use the yellow wire as a ref point it looks like the hub on the pulley is running nice and true while the bolt is wobbling about.
To me (I have been wrong lots) in the last of your 1st photos, it looks like a sharp edge on the inside of the gear around the hole. This would mean that the gear was moving. I can't tell from the pics but is the cam damaged?
It could be the bolt is bottomed out and the gear is moving on the cam.
More exploring and better pics of cam end are required.
