When to replace shocks
My '80 928 feels a bit soft to me and the odometer
says 90k. The shocks are original as far as I can tell.
If pushed hard into a turn I get a bounce that does not inspire confidence to go deeper.
Hoping for a stiffer suspension and about to replace the front
springs with a later model "S" which should lower it a bit and stiffen it some but ......
Question is should I replace the shocks and with what?
Vanster
Oakland CA
1980 5sp
Vanster
Oakland CA
1980 5sp
Well... 30 years old, 90k miles, I'd say those shocks are toast. Fer sure. As for putting S springs in there, I just did that on an 80 5spd, and it's an improvement but nothing remarkable. Fresh shocks will make a huge difference, most are generally only fair after 20k miles. If you want stiffer and lower, go with the Eibach's. Shocks: buy the best ones you can afford for what you're doing with the car. Just commuting to work... boges. Track days... bilsteins,konis, etc.
Basic Site Sponsor
Basic Site Sponsor
Put in a set of Bilsteins, with a set of later front springs (which are required for your application). Best money you will ever spend on your car. People suffer with the stock shocks for way too many years, because they don't seem to leak and they don't bounce multiple times when you push on the fender.
Stiffer springs are fun for about a week and then you will start to dislike the ride, as it slowly beats you and your car to death. I take aftermarket springs out way more often than I install them.
greg brown
714 879 9072
GregBBRD@aol.com
Semi-retired, as of Feb 1, 2023.
The days of free technical advice are over.
Free consultations will no longer be available.
Will still be in the shop, isolated and exclusively working on project cars, developmental work and products, engines and transmissions.
Have fun with your 928's people!
greg brown
714 879 9072
GregBBRD@aol.com
"Stiffer springs are fun for about a week and then you will start to dislike the ride, as it slowly beats you and your car to death. I take aftermarket springs out way more often than I install them. "
Interesting comment, I'm ready to replace my stock Gray Boge's and springs with Bilstien and Eibach springs. What springs are you suggesting; stock?
Chronic Tool Dropper
If your car is a weekend driver, the Eibach springs and Bilstiens will bring a smile to your face, particularly in spirited driving. The car corners amazing flat with the Eibachs. Simpls is that double the spring rate halves the body roll. The progressive nature makes the stiffe ride tolerable. The Bilstiens give great control with the stiffer springs. Combo is much more sports-car than grand touring as far as ride quality.
Team Owner
and if your going to use the car as it was meant to be used,
aftermarket springs will have you wanting for a smoother ride,
As Greg points out I also put the Bilstiens with stock springs on my 88,
it rides great,
handles great
and for long distances is just about perfect
NOTE long distance is over 1000 miles or 3 states
it rides great,
handles great
For those planning the stock spring + Bilstein setup, would you do new springs at 141k miles? Not sure I ever heard a consensus on whether springs wear out, and we can adjust ride height to compensate for any shortening ...
Thats a good question, I have approx same miles 130k.
Thanks everyone
Bilstein's it is with the stock later springs. Thanks everyone for your input. I am more a long distance driver/ SF-LA and planing a trip this spring across country SF/Maine
I am an ex vintage racer (Lotus Cortina - Alfa- F Fords) Cars set up for racing and driving on the streets (pot holes) is not fun. But driving with spirit and knowing that
your car is going to go where you point it is great fun, even better when the tail comes around a bit
Onwards and sideways!
vanster
vanster
Mine car had M474 Sport Suspension from factory. I replaced the front shocks before I knew they could be rebuilt, then a bit later rebuilt the rears. As said above, beautiful set up. A bit firm on rough suburban streets, but out on the road, absolutely great.
jp 83 Euro S AT 52k
jp 83 Euro S AT 52k
Basic Site Sponsor
Basic Site Sponsor
