928 Forum 1978-1995
Sponsored by: 928 Specialists
Intake manifold sensor
Old Oct 7, 2010 | 11:05 AM
supercedar's Avatar
supercedar
Default Intake manifold sensor
Should the sensor on the top rear of intake turn where the wires connect on my 1988 S4?
Thank you!
Thomas
Old Oct 7, 2010 | 11:09 AM
dprantl's Avatar
dprantl
No.
Dan
'91 928GT S/C 475hp/460lb.ft
Old Oct 7, 2010 | 11:13 AM
supercedar's Avatar
supercedar
Originally Posted by dprantl
No.
Dan
Thanks Dan, What is its purpose?
Old Oct 7, 2010 | 11:28 AM
dprantl's Avatar
dprantl
I believe that is a temp sensor that will turn on the fans after the engine is shut off if the intake air temp is too high. If something on this sensor is turning, then it may be a vacuum leak.
Dan
Old Oct 7, 2010 | 11:53 AM
auzivision's Avatar
auzivision
That hole doesn't go all the way through the metal so no air will leak. Also, I do believe it will trigger the fans if you short out the wires and push the hood closed button. I was also thinking it can retard the timing slightly if it senses the intake is hot.
Old Oct 7, 2010 | 12:54 PM
SQLGuy's Avatar
SQLGuy
It's just a switch for the fans. I'm pretty sure there's a separate inlet air temp sensor that's used to adjust timing and mixture... the one built into the MAF may be used for this dual purpose.
Old Oct 7, 2010 | 01:24 PM
Rob Edwards's Avatar
Rob Edwards
Archive Gatekeeper
The two connector terminals are molded into some sort of plastic insert in the brass body of the sensor (928 606 217 00). On the GTS mine was turning inside the sensor, and Greg took it and threw it in the trash.
Old Oct 7, 2010 | 01:51 PM
supercedar's Avatar
supercedar
You guys are great.
Thomas
Old Oct 7, 2010 | 02:12 PM
Shark_Week's Avatar
Shark_Week
Rob, did you get a new sensor?
Old Oct 7, 2010 | 02:18 PM
Rob Edwards
Archive Gatekeeper
Yep, $35ish.
