928 Forum 1978-1995
Sponsored by: 928 Specialists
Headlight bar install question
Old Oct 3, 2010 | 11:11 AM
Ducman82's Avatar
Ducman82
Veteran: Air Force
Default Headlight bar install question
If my hand in this pic was the fender wall, does the black plastic mount go on inside of the fender and the "nut bar" goes on the inside so you have to install the bolts from under the assembly? or does the bolts go in to the plastic part then in to the nut bar inside the fender?
File Type: jpg
Old Oct 3, 2010 | 11:44 AM
Mrmerlin's Avatar
Mrmerlin
Team Owner
the bolts pass from the engine compartment through the fenderwell ,
the plastic is sandwiched tween the nut plate to the outside of the fender
Old Oct 3, 2010 | 12:03 PM
heinrich's Avatar
heinrich
928 Collector
First time I've seen a new one ... GORGEOUS!!!!
Old Oct 3, 2010 | 12:14 PM
Ducman82's Avatar
Ducman82
Veteran: Air Force
not new, re-plated! The plate shop here in town loves me.....
