S4 TB/WP job, which bolt(s) need sealing?
Working on an 87.
One of the long thin cover bolts on DS looked/smelled like it was in an engine oilway. Is this typical? I don't remember this on S3's I've done.
During this job, are any bolts that need removing in oilways or waterway?
Basic Site Sponsor
Basic Site Sponsor
Originally Posted by Landseer;
Working on an 87.
greg brown
714 879 9072
GregBBRD@aol.com
Semi-retired, as of Feb 1, 2023.
The days of free technical advice are over.
Free consultations will no longer be available.
Will still be in the shop, isolated and exclusively working on project cars, developmental work and products, engines and transmissions.
Have fun with your 928's people!
greg brown
714 879 9072
GregBBRD@aol.com
Team Owner
the other bolt that can leak is the front lower timing cover long bolt this one goes through one of the b securing holes for the WP if you get it out and its corroded it should be replaced.
also replace the WP bolts, Ace has those as well.
I have been using the loctite non setting pipe thread sealant with PTFE on the WP bolts and tensioner pivot and tensioner mounting bolt no leaks and they come out without corrosion
